Home » Modeling » TMF (Xtext) » Question on cross-referencing and scoping
Question on cross-referencing and scoping [message #1016248] Tue, 05 March 2013 11:01 Go to next message
Hi all Smile
I have a question on cross-referencing and scoping: if I declare in my DSL grammar a cross-reference and I do not define a particular scope for it, which is the default one?
If my cross-reference has type T, should I always see all occurences of T in the model, right?
Re: Question on cross-referencing and scoping [message #1016255 is a reply to message #1016248] Tue, 05 March 2013 11:40 Go to previous messageGo to next message
you see all instances of T (inclusive subtypes) in all model files in the project (and referenced ones) if they are exported to the xtext index (= have a name attribute)
~Christian
Re: Question on cross-referencing and scoping [message #1016256 is a reply to message #1016255] Tue, 05 March 2013 11:41 Go to previous messageGo to next message
P.S:
And the qualified name has to be serializable at the point
[T] is short for the [T|ID] => a ID will parsed and you wont see thze objects if their name contains a .
Re: Question on cross-referencing and scoping [message #1016422 is a reply to message #1016256] Wed, 06 March 2013 07:06 Go to previous messageGo to next message
Christian Dietrich wrote on Tue, 05 March 2013 11:41
P.S:
I think this is my problem, because on method content assist I only see the methods declared in the same mixin where I'm writing code, and not the others.
And in fact I'm using qualified names:
fragment = exporting.QualifiedNamesFragment {}
However, as in Java editor, on a method call I don't want to refer to the called method using a qualified name as (for example):
ClassName.methodName
but a simple one:
methodName
How can I get this? Rolling Eyes I have to enable the SimpleNamesFragment instead of the QualifiedNamesFragment one?
Thanks in advance,
Marco
Re: Question on cross-referencing and scoping [message #1016444 is a reply to message #1016422] Wed, 06 March 2013 08:29 Go to previous messageGo to next message
Did you try [T|FQN]
With FQN : ID ("." ID)*;
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: Question on cross-referencing and scoping [message #1016456 is a reply to message #1016444] Wed, 06 March 2013 09:10 Go to previous messageGo to next message
Yes, I tried, in that way I see all methods in content assist drop-down, but I obtain this error message when I generate Xtext Artifacts from grammar:
Decision can match input such as "'.' RULE_ID '.' RULE_ID '.' RULE_ID '.' RULE_ID" using multiple alternatives: 1, 2
that is, my grammar is now ambiguous, right?
Re: Question on cross-referencing and scoping [message #1016461 is a reply to message #1016456] Wed, 06 March 2013 09:44 Go to previous messageGo to next message
Yes so you can either fix that use simple name provider or give
explicitly a simple name in the defaultdeclarativenameprovider
Re: Question on cross-referencing and scoping [message #1016977 is a reply to message #1016255] Fri, 08 March 2013 07:39 Go to previous message
On 03/05/2013 05:40 PM, Christian Dietrich wrote:
> Hi
> ~Christian
Sorry if I jump in the discussion:
if there are containment relations the default scoping will take care of
that, won't it? Because of the default qualified name provider which
takes containment relation into account, right?
HOME: http://www.lorenzobettini.it
Previous Topic:Errors and Warnings while running workflow
Next Topic:2-step generating
Current Time: Sat Jul 19 15:56:18 EDT 2025
Powered by FUDForum. Page generated in 0.04814 seconds
