[EMFStore] Updating the model on the server side based on clients modifications [message #1015831] |
Sun, 03 March 2013 07:31  |
Hello everyone,
I am trying to develop a library for Ecore models. To persist the models, I use a graph database that is stored on a Rexster server. As far as I know, the server supports multiple user access. I am looking for efficient ways to update the models on the server side based on the clients modifications.
I watched the video on the homepage of EMFStore. It seems that the models on the
server are updated after each modification of clients. I would like to know how this is achieved.
I know that EMF supports notifications. So, I could register Adapter and listen to changes.But this could be ineffective in my opinion because notifications must first be sent over the network. In addition, a notification is sent for each modification on the model. When we know consider the fact that sereval users can work on the same model, reacting directly on the notification could lead to inconsistency.
Another possibility that I am considering is to override the hashCode()-method. After a client has committed his changes, I could compute the hash of all EObjects of a model and compared them with the hash of objects that are stored in the library. Based on the differences I could update the graph. One disadvantage of this approach is that I won't know which property of an object was changed. I would have to do a whole comparison. The last possibility is brute force, which I want to avoid.
Could someone (in the EMFStore team) tell me how I could update the server models?
Any idea is welcome.
Many thanks
Junior
Re: [EMFStore] Updating the model on the server side based on clients modifications [message #1015927 is a reply to message #1015831] |
Mon, 04 March 2013 04:41  |
EMFStore records the notifications on the client-side as so-called
operations. An operation can describe the result of several
notifications and is considered an atomic change. For example deleting
an EObject including all its cross-references to remaining EObjects is
an operation.
EMFStore stores the operations on the client side until a commit is
requested. On commit the operations are send to the server and used for
conflict detection (detecting overlapping changes) and for
synchronization of the model/graph on the server and other clients.
Maybe it makes sense for you to reuse EMFStore or parts of EMFStore.
Hope this helps, let me know if you have more questions!
Maximilian
Am 03.03.2013 13:31, schrieb Junior Lekane Nimpa:
> Hello everyone,
> models on the server are updated after each modification of clients. I
> would like to know how this is achieved. I know that EMF supports
> avoid.
> server models?
> Many thanks
> Junior
Maximilian Kögel
Get Professional Eclipse Support: http://eclipsesource.com/munich
FUDForum. Page generated in 0.03611 seconds
