Home » Archived » Hudson » Python API URL is responding with 404 Not Found
icon9.gif  Python API URL is responding with 404 Not Found [message #1015631] Fri, 01 March 2013 08:07 Go to next message
We just updated to Hudson 3.0.0 from our 2.3 installation, but have been having problems with another system which integrates with hudson via the Python API.
If I call servername:8080/job/myjob/api/python I just get:
HTTP ERROR 404
Problem accessing /job/myjob/api/python. Reason:
    Not Found
Powered by Jetty://
The XML interface seems OK, but not the python one. This did work prior to the upgrade.
Can anyone assist in what might be happening or why the python API does not seem to be working?
Re: Python API URL is responding with 404 Not Found [message #1015656 is a reply to message #1015631] Fri, 01 March 2013 09:46 Go to previous messageGo to next message
Agreed I see this problem as well - I've logged 402138 to track this and marked it for fixing in 3.0.1.
Re: Python API URL is responding with 404 Not Found [message #1015685 is a reply to message #1015631] Fri, 01 March 2013 12:22 Go to previous messageGo to next message
OK it seems that we dropped Python support during the migration process to Eclipse because of some IP issues??
Anyway looking at the code involved the "python" support is just a simple extension of the JSON support (that is there) with the basic exception of the treatment of null values and booleans
So booleans are written as "True" in the python writer as opposed to "true", ditto in the case of false
Null values are written as "None"
So, if you switch to the /api/json doe it actually work for you? I suppose it depends on your parser...?
Re: Python API URL is responding with 404 Not Found [message #1015687 is a reply to message #1015685] Fri, 01 March 2013 12:31 Go to previous messageGo to next message
Just checked and the Python JSONDecoder() will handle these differences for you
http://docs.python.org/3.3/library/json.html section 19.2.2
So it should be sufficient to use the JSON APIs
Re: Python API URL is responding with 404 Not Found [message #1015891 is a reply to message #1015687] Mon, 04 March 2013 03:15 Go to previous message
Thanks Duncan - unfortunately the other software we are using doesn't allow us to directly specify the full API URL reference (it adds on the /api/python itself). Will raise bug with them also. Strange it was dropped for IP issues though if the code is almost identical to the JSON API?
Previous Topic:utter newbie user cannot login
Next Topic:Next Community Meeting
Current Time: Sun Jul 20 14:55:45 EDT 2025
Powered by FUDForum. Page generated in 0.04686 seconds
