Home » Archived » Buckminster » Build is slow with buckminster 4.2
Build is slow with buckminster 4.2 [message #1015544] Fri, 01 March 2013 03:28 Go to next message
Hi!
I have updated my build server from buckminster 3.7 to 4.2 and besides problems with emma and jenkins (misunderstandings about the log format) I also noticed that it takes a lot longer to build with the new one!
One of the problems seems to be between the junit runs, where there is now a pause of about one minute, see log snippet below, but is not the only culprit.
Switching between the buckminster versions gives immediate and clear results (7 versus 19 minutes). Does anyone know what the problem might be and how to fix it?
best regards,
Vlad
09:15:45,483 I: (ErtsWatcher.java:73) : Backend '79825_jenkins_53b34_erlide' terminated with exit code 0.
INFO:  junit '-l' 'org.erlide.testing/junit_core.launch' '-o' '/var/lib/jenkins/jobs/vlad_any/workspace/output/junit_result_core.xml' '--flatXML' '--terseXML' '--stderr' '--stdout'
09:16:50,067 F: (ErlangCore.java:77) : Starting CORE Thread[main,5,main]
[Updated on: Fri, 01 March 2013 03:28] by Moderator
Re: Build is slow with buckminster 4.2 [message #1016004 is a reply to message #1015544] Mon, 04 March 2013 10:15 Go to previous messageGo to next message
can it be related to this buckminster's junit command line argument?
--maxTimeAwaitJunitReport
If your JUnit reports are huge (more than 200MB) then it may take some
time to work them up
and Buckminster finishes before the VM has had time to process the data.
The duration given with --maxTimeAwaitJunitReport will define the
maximum amount of time in seconds
to wait until the JUnit report should be created. The default is 10
seconds.
On 03/01/2013 09:28 AM, Vlad Dumitrescu wrote:
> Hi!
> only culprit.
> best regards,
> Vlad
HOME: http://www.lorenzobettini.it
Re: Build is slow with buckminster 4.2 [message #1016008 is a reply to message #1016004] Mon, 04 March 2013 10:18 Go to previous messageGo to next message
I'll check that out. Thanks Lorenzo!
But there are also the one minute pauses between the junit runs, so there is something else too...
/Vlad
Re: Build is slow with buckminster 4.2 [message #1035888 is a reply to message #1016008] Sun, 07 April 2013 12:05 Go to previous messageGo to next message
some follow-ups: I tried to run buckminster 4.2 headless with
-L DEBUG
and the whole build time is less than half!
For instance
without -L DEBUG: 11 minutes 41 seconds
with -L DEBUG : 4 minutes 40 seconds
I have both plain Junit tests, Plug-in Junit tests, and Swtbot tests in
this build...
> /Vlad
Re: Build is slow with buckminster 4.2 [message #1122631 is a reply to message #1035888] Tue, 01 October 2013 15:38 Go to previous message
I think I found the problem :)
I submitted a patch:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=418453
cheers
Lorenzo
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Previous Topic:Dependency version problem in equinox launchers
Next Topic:junit command using p2 site
Current Time: Sat Jul 19 16:42:07 EDT 2025
Powered by FUDForum. Page generated in 0.33341 seconds
