Home » Newcomers » Newcomers » SWT Tutorial doesn't work?(The SWT tutorial on the main eclipse Welcome page doesn't work? )
SWT Tutorial doesn't work? [message #726851] Mon, 19 September 2011 13:38 Go to next message
I suspect this is a VERY dumb new-user trick, however....
I downloaded and installed the latest Eclipse for Java (32bit Indigo).
I downloaded and installed the latest SDK (v7, 32bit).
I successfully built and ran the basic "Hello World" tutorial.
But when I try to follow the instructions for the SWT tutorial shown on the Tutorials Welcome page, titled
"Create a Hello World SWT application"
they do not work.
The first step is:
Open the Import wizard from the main menu via File > Import..., and select Plug-in Development > Plug-ins and Fragments. Click Next.
However, there is no Plug-in Development menu item.
I've tried:
installing SWT separately,
using the "Click to Perform" options,
All fail.
Sorry to take folks time with something so trivial, but any advice / suggestions on what basic step(s) I've missed? I'm stumped....
(no subject) [message #726860 is a reply to message #726851] Mon, 19 September 2011 13:54 Go to previous messageGo to next message
> the Tutorials Welcome page, titled "Create a Hello World SWT application"
> they do not work.
> The first step is:
> I've tried:
> installing SWT separately, using the "Click to Perform" options,
> All fail.
Which Eclipse package did you download? It may be one that doesn't have
support for plug-in development. I'm not certain which one has that; it
might be "Classic".
Re: (no subject) [message #726867 is a reply to message #726860] Mon, 19 September 2011 14:30 Go to previous messageGo to next message
Thanks for the response!
I downloaded the SE (Standard Edition) found here:
http: //www .eclipse.org/downloads/packages/eclipse-ide-java-developers/indigor
(since the forum won't let me post a link until I've got 5 posts, I stuck in two spaces...)
This appears to be the "default" version for non-enterprise work. Is there a better choice?
(no subject) [message #727206 is a reply to message #726860] Tue, 20 September 2011 11:42 Go to previous messageGo to next message
>> they do not work.
>> The first step is:
>> I've tried:
>> All fail.
> might be "Classic".
Either Eclipse Classic or "Eclipse for RCP and RAP Developers" would
work for SWT development.
You can also use Help > Install New Software... to install the PDE stuff
into your Eclipse. In the install dialog, select the Indigo repository
to work with, then find "Eclipse plug-in development environment" in the
list, select that, and install.
Eric
Re: SWT Tutorial doesn't work? [message #911017 is a reply to message #727206] Mon, 10 September 2012 16:18 Go to previous messageGo to next message
I realize this is in response to a rather old post but I was having the same problem in trying the SWT tutorial. I am using Eclipse Juno 4.2.
I found this
www.java-forums.org/eclipse/53817-having-problems-getting-started-eclipse.html
where it states:
Help -> Install New Software
Work with: --All Available Sites--
General Purpose Tools -> Eclipse Plug-in Development Environment
[Finish]
After installing this plug-in and restarting Eclipse, you will be able to proceed with the tutorial.
I installed this plug-in, everything is now hunky-dory!
icon10.gif  Re: SWT Tutorial doesn't work? [message #956074 is a reply to message #911017] Wed, 24 October 2012 04:09 Go to previous messageGo to next message
thx,btw, maybe it's :
Mobile and ...(forget) -> Eclipse Plug-in Development Environment
icon8.gif  Re: SWT Tutorial doesn't work? [message #961835 is a reply to message #956074] Sun, 28 October 2012 12:43 Go to previous messageGo to next message
I'm having a different problem with the SWT Tutorial. The below is what errors I'm getting:
Exception in thread "main" java.lang.UnsatisfiedLinkError: Could not load SWT library. Reasons:
no swt-win32-4234 in java.library.path
no swt-win32 in java.library.path
Can't load library: C:\Users\Larry\.swt\lib\win32\x86_64\swt-win32-4234.dll
Can't load library: C:\Users\Larry\.swt\lib\win32\x86_64\swt-win32.dll
Re: SWT Tutorial doesn't work? [message #1015315 is a reply to message #961835] Thu, 28 February 2013 03:25 Go to previous messageGo to next message
Copy files from
C:\Program Files\eclipse\configuration\org.eclipse.osgi\bundles\195\1\.cp\
to
C:\Users\<username>\.swt\lib\win32\x86_64\
where <username> is your username.
Re: SWT Tutorial doesn't work? [message #1184686 is a reply to message #1015315] Wed, 13 November 2013 11:20 Go to previous message
I had the same problem.
I am surprised by the solution. How did you find out ??
The error message was :
and the solution is to copy...
C:\Program Files\eclipse\configuration\org.eclipse.osgi\bundles\195\1\.cp\[\i]
the files : (!!)
swt-gdip-win32-4234.dll
and
swt-gdip-4234.dll
thank you so MUCH !
Marc
I would have never found this ..
Previous Topic:XText
Next Topic:Show in folder button
Current Time: Sat Jul 19 14:53:44 EDT 2025
Powered by FUDForum. Page generated in 0.09564 seconds
