Home » Archived » Hudson » Hudson + SVN + Eclipse
Hudson + SVN + Eclipse [message #997289] Fri, 04 January 2013 19:21 Go to next message
Hi, I'm trying to make Hudson + SVN work on Eclipse. I have successfully installed Hudson and SVN servers, and their admin interfaces are accessible.
I installed the plugins in Eclipse so I can access SVN repository successfully, and I can see build results inside Eclipse shell, but I'm not sure I can run builds correctly.
The problem is that I haven't been able to generate builds in Hudson in sync with source code changes done in a simple Java project in Eclipse.
I may be missing some initialization on the Hudson side. Are there any tutorials, or even better examples showing the integration of these tools?
Any help will be appreciated.
Configuration:
Eclipse Juno SR1
SVN 1.7
Hudson 3.0
Windows 7
Thanks!
Re: Hudson + SVN + Eclipse [message #997293 is a reply to message #997289] Fri, 04 January 2013 20:34 Go to previous messageGo to next message
Make sure you enable the "Poll SCM" option enabled. Basically this option will tell hudson every x minutes to scan the svn repository for any new changes. If changes are found it will perform an update and and perform a build. If no changes are found it will not trigger a new build. The hudson book is available at http://wiki.eclipse.org/Hudson-ci#The_Hudson_Book.
Re: Hudson + SVN + Eclipse [message #1014997 is a reply to message #997293] Wed, 27 February 2013 02:45 Go to previous message
I setup my job exactly as what you said here. The build is triggered but it only do the svn update steps then stops. I will post a new message for the issue.
Previous Topic:Hudson not triggering a build when it receives SVN commit notification?
Next Topic:Hudson version compatible with Java 1.7
Current Time: Sun Jul 20 02:21:13 EDT 2025
Powered by FUDForum. Page generated in 0.03412 seconds
