Home » Eclipse Projects » Equinox » NoClassDefFoundError
NoClassDefFoundError [message #101497] Wed, 14 November 2007 09:55 Go to next message
Originally posted by: pfischer06.fast-mail.org
I try to start an equinox based app in eclipse:
- two bundles A und B: A exports some interfaces and classes and B is
using them
- B has A as required-bundle.
- eclipse shows no compiler errors
- validating the equinox-start-configurarion shows no error
- starting the app, the osgi-consle shows all needed bundles activated.
But:
calling then functions of bundle B throws an
java.lang.NoClassDefFoundError for an Interface of A implemented in B.
What do I wrong?
regards,
Peter
Re: NoClassDefFoundError [message #101509 is a reply to message #101497] Wed, 14 November 2007 10:13 Go to previous messageGo to next message
Peter Fischer wrote:
> Hello,
> using them
> But:
> What do I wrong?
> regards,
> Peter
From what you describe I do not see a reason it is failing. Are you
launching eclipse from your workspace with a launch configuration
(self-hosting)? Or are you exporting the bundle jars and installing
them into an eclipse installation? If so can you confirm the interface
class got included in the bundle? If you have a simple testcase can you
attach it here?
Tom
Re: NoClassDefFoundError [message #101522 is a reply to message #101497] Thu, 15 November 2007 03:18 Go to previous message
Originally posted by: sf.tragwerk-dresden.de
Make sure that the plugin is activated when one of its classes is
loaded. Your MANIFEST.MF should contain the line
Eclipse-LazyStart: true
Sebastian
Previous Topic:Eclipse Help System - org.eclipse.help.webapp (conflict with RAP or equinox)
Next Topic:Did somebody use JUnit to test OSGi application?
Current Time: Sat Jul 19 06:32:53 EDT 2025
Powered by FUDForum. Page generated in 0.24772 seconds
