httpexception 500 internal server error [message #1014832] |
Tue, 26 February 2013 10:00  |
Hi all,
I''m new to the use of scout ... I have developed my application and I was doing some tests. At some point, by starting Swing or SWT, Eclipse has started to give me the following message: httpexception 500 internal server error.
The strange thing is that the server starts successfully.
In the eclipse console I can read this:
!SESSION 2013-02-26 15:57:12.714 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_24
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=it_IT
Framework arguments: -product org.zeiss.mo.scout.CZVEDIController.ui.swing.product
Command-line arguments: -product org.zeiss.mo.scout.CZVEDIController.ui.swing.product -data C:\Projects\scout/../runtime-CZVEDIController-swing-client-dev.product -dev file:C:/Projects/scout/.metadata/.plugins/org.eclipse.pde.core/CZVEDIController-swing-client-dev.product/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog
!ENTRY org.eclipse.scout.rt.client 4 0 2013-02-26 15:57:19.167
!MESSAGE org.eclipse.scout.rt.client.AbstractClientSession.startSession(AbstractClientSession.java:257) load session
!STACK 0
java.lang.reflect.UndeclaredThrowableException
at $Proxy6.getAllCodeTypeClasses(Unknown Source)
at org.eclipse.scout.rt.client.services.common.code.CodeServiceClientProxy.getAllCodeTypeClasses(CodeServiceClientProxy.java:342)
at org.eclipse.scout.rt.client.services.common.code.CodeServiceClientProxy.getAllCodeTypes(CodeServiceClientProxy.java:363)
at org.eclipse.scout.rt.shared.services.common.code.CODES.getAllCodeTypes(CODES.java:64)
at org.zeiss.mo.scout.CZVEDIController.client.ClientSession.execLoadSession(ClientSession.java:48)
at org.eclipse.scout.rt.client.AbstractClientSession.startSession(AbstractClientSession.java:252)
at org.eclipse.scout.rt.client.services.common.session.internal.ClientSessionRegistryService$1.runVoid(ClientSessionRegistryService.java:70)
at org.eclipse.scout.rt.client.ClientJob.runStatus(ClientJob.java:177)
at org.eclipse.scout.rt.client.ClientJob.runTransactionWrapper(ClientJob.java:161)
at org.eclipse.scout.rt.client.ClientJob.run(ClientJob.java:149)
at org.eclipse.scout.commons.job.JobEx.runNow(JobEx.java:50)
at org.eclipse.scout.rt.client.services.common.session.internal.ClientSessionRegistryService.createAndStartClientSession(ClientSessionRegistryService.java:74)
at org.eclipse.scout.rt.client.services.common.session.internal.ClientSessionRegistryService.newClientSession(ClientSessionRegistryService.java:45)
at org.zeiss.mo.scout.CZVEDIController.ui.swing.SwingApplication.getClientSession(SwingApplication.java:62)
at org.eclipse.scout.rt.ui.swing.AbstractSwingApplication.startInSubject(AbstractSwingApplication.java:179)
at org.eclipse.scout.rt.ui.swing.AbstractSwingApplication.start(AbstractSwingApplication.java:141)
at org.zeiss.mo.scout.CZVEDIController.ui.swing.SwingApplication.startSecure(SwingApplication.java:57)
at org.zeiss.mo.scout.CZVEDIController.ui.swing.SwingApplication.access$0(SwingApplication.java:49)
at org.zeiss.mo.scout.CZVEDIController.ui.swing.SwingApplication$1.run(SwingApplication.java:39)
at javax.security.auth.Subject.doAs(Unknown Source)
at org.zeiss.mo.scout.CZVEDIController.ui.swing.SwingApplication.start(SwingApplication.java:36)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: ProcessingException[ProcessingStatus[ERROR code=0 Calling ICodeService.getAllCodeTypeClasses() org.eclipse.scout.rt.shared.servicetunnel.HttpException: 500 - INTERNAL_SERVER_ERROR]]
at org.eclipse.scout.rt.client.servicetunnel.AbstractServiceTunnel.invokeService(AbstractServiceTunnel.java:163)
at org.eclipse.scout.rt.client.servicetunnel.http.internal.InternalHttpServiceTunnel.invokeService(InternalHttpServiceTunnel.java:174)
at org.eclipse.scout.rt.client.servicetunnel.http.HttpServiceTunnel.invokeService(HttpServiceTunnel.java:115)
at org.eclipse.scout.rt.client.servicetunnel.ServiceTunnelInvocationHandler.invoke(ServiceTunnelInvocationHandler.java:47)
at org.eclipse.scout.rt.client.servicetunnel.AbstractServiceTunnel.invokeService(AbstractServiceTunnel.java:167)
... 35 more
Caused by: org.eclipse.scout.rt.shared.servicetunnel.HttpException: 500 - INTERNAL_SERVER_ERROR
at org.eclipse.scout.rt.client.servicetunnel.http.internal.HttpBackgroundJob.runStatus(HttpBackgroundJob.java:85)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
Someone have had the same thing? How can I fix?
thanks in advance for the help
Re: httpexception 500 internal server error [message #1015003 is a reply to message #1014913] |
Wed, 27 February 2013 02:53  |
I check link that you suggest me.
At the end the problem is located on Common Service for SQL Services, I delete and recreate this service and now all works fine.
Thank you for your help.
[Updated on: Wed, 27 February 2013 03:21] by Moderator
FUDForum. Page generated in 0.14516 seconds
