Home » Eclipse Projects » NatTable » Selection and focus
Selection and focus [message #1014263] Mon, 25 February 2013 08:19 Go to next message
I am using NatTable and the GlazedListGridLayer class from one of the examples and I am reading large sets of data from file into the table (~ more than 1M rows and some processing while reading so it takes awhile).
During the reading process I want to be able to right-click on rows and select actions depending on the contents of the row. However with my current implementation the selection is lost when new rows are added (via the underlying event list). Have I implemented it wrong somehow to cause this behavior? Or is there some way to pause table updates for awhile so that I can select rows when I need to?
Re: Selection and focus [message #1015162 is a reply to message #1014263] Wed, 27 February 2013 10:41 Go to previous messageGo to next message
I need to investigate a bit further on this. And there is already an open ticket on it:
AFAIK this is related to the SelectionLayerStructuralChangeEventHandler. This one clears the selection on changes to the vertical structure. It might be that it clears to often or determines to clear the selection to often. I'm not quite sure about this yet.
There might be a workaroung for you until the bug is fixed. You can create the SelectionLayer telling to not use the default event handler. Then instead register another event handler that could look like this:
public class PreserveSelectionStructuralChangeEventHandler implements ILayerEventHandler<IStructuralChangeEvent> {
	private final SelectionLayer selectionLayer;
	public PreserveSelectionStructuralChangeEventHandler(SelectionLayer selectionLayer) {
		this.selectionLayer = selectionLayer;
	public Class<IStructuralChangeEvent> getLayerEventClass() {
		return IStructuralChangeEvent.class;
	public void handleLayerEvent(IStructuralChangeEvent event) {
		PositionCoordinate[] coords = this.selectionLayer.getSelectedCellPositions();
		for (PositionCoordinate coord : coords) {
			if (coord.getColumnPosition() >= this.selectionLayer.getColumnCount()
					|| coord.getRowPosition() >= this.selectionLayer.getRowCount()) {
				//if the coordinates of the selected cells are outside the valid range remove the selection
				this.selectionLayer.clearSelection(
						coord.getColumnPosition(),
						coord.getRowPosition());
Note that this should be only a workaround. I will investigate on this in more detail to found a general solution.
Greez,
Dirk
Re: Selection and focus [message #1015352 is a reply to message #1015162] Thu, 28 February 2013 05:15 Go to previous message
Thank you! Your suggested workaround did the trick.
Previous Topic:KeyEvents not getting registered on WizardDialog
Next Topic:Is 1.0.0 actually released?
Current Time: Sat Jul 19 16:34:01 EDT 2025
Powered by FUDForum. Page generated in 0.05219 seconds
