Home » Newcomers » Newcomers » Need connection object used by EntityManager(Help)
Need connection object used by EntityManager [message #1012600] Thu, 21 February 2013 16:32 Go to next message
I am using EclipseLink under WebLogic 12c. I need to get access to the underlying java.sql.Connection object being used by the EntityManager in an EJB. I'm not going to waste time going into the reasons for this, I know most people will think it's not necessary, but I need that connection. I found the following example at http://wiki.eclipse.org/EclipseLink/Examples/JPA/EMAPI#Getting_a_JDBC_Connection_from_an_EntityManager
entityManager.getTransaction().begin();
java.sql.Connection connection = entityManager.unwrap(java.sql.Connection.class);
entityManager.getTransaction().commit();
But this does not work, I get null returned from the call to entityManager.unwrap(java.sql.Connection.class);
Is there another way to get the connection?
Thanks for any help!
Re: Need connection object used by EntityManager [message #1012948 is a reply to message #1012600] Fri, 22 February 2013 09:00 Go to previous message
It appears EclipseLink is supported in and by a different forum. You
might not get much help here. Check out:
http://www.eclipse.org/forums/index.php/f/111/
and/or
http://www.eclipse.org/eclipselink/
Previous Topic:Error: java.lang.NullPointerException
Next Topic:eclipse plugin error
Current Time: Sat Jul 19 06:06:54 EDT 2025
Powered by FUDForum. Page generated in 0.09368 seconds
