Home » Eclipse Projects » Eclipse Platform » Retarget Debug actions are not enabled on editor page change(Keybinding with Togglebreakpoint action does not work)
Retarget Debug actions are not enabled on editor page change [message #1012287] Thu, 21 February 2013 04:18 Go to next message
Hi All,
The Toggle breakpoint action (contributed by the debug framework) is a global (Retarget) action which gets activated whenever a part is activated.
I have a multipage editor which has a source editor as the last tab. So when the editor opens the actions are not enabled as i dont have an adaptable selection which is fine. (The scenario is working fine when i make the source code editor as the first tab as the text selection enables the debug actions)
But i think on the page change of tabs this action should be enabled which is not happening. Debugged a lot and could not find any satisfactory solution.
I might be missing something very simple.
cheers,
Saurav
Re: Retarget Debug actions are not enabled on editor page change [message #1015146 is a reply to message #1012287] Wed, 27 February 2013 10:15 Go to previous message
A bugzilla entry related to the issue discussed.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=401689
cheers,
Saurav
Previous Topic:Enum in Eclipse Scrapbook
Next Topic:Command handlers in custom non-modal window
Current Time: Sat Jul 19 23:23:32 EDT 2025
Powered by FUDForum. Page generated in 0.03450 seconds
