Generating a config.xml file [message #1010854] |
Mon, 18 February 2013 05:46  |
Hello all,
This is my first post in here.
We had a task to generate a config.xml file for one of our projects which is in turn a code generator, using an UI based editor rather than typing via XML source.
I came across Sapphire and tried to model it our use case using the Bug Repository samples. But i was not successful in doing so.
I have to generate the XML based on the selection of Java Models (POJOs) from a package and other additional inputs like view, input-types and so on.
The end product XML that is expected to be generated is a JSF xml configuration file.
1. Is Sapphire the way to do it ? If yes, from where do i start? or what am i doing wrong ( I will be happy to provide you additional information on what i have done ) ?
2. Are tools like Java EE WTP (built on Sapphire) to generate the configuration file, is the way to do it ?
Thanks in advance for your suggestions and help ?
Harsha
FUDForum. Page generated in 0.27609 seconds
