Home » Modeling » Model-to-Model Transformation » "Many-Model to Model" transformation with qvto?
"Many-Model to Model" transformation with qvto? [message #1011932] Wed, 20 February 2013 09:33 Go to next message
Hi all,
I am still new to qvto but my newest project already provides my with kind of a special issue which I could not find an answer for up to now:
In my project I want to transform several input models (xml files), that are all based on the same meta-model, to one single output model (uml).
Is there a way to do such a "many-model to model" transformation in qvto or is only one input model possible at a time?
If this does not work, another approach could be to use a programm/script to do the model-to-model transformations seperately and then join them afterwards.
Regarding this second approach my question is: Is it possible to execute qvto commands in java code?
Thanks a lot,
Miriam
Re: "Many-Model to Model" transformation with qvto? [message #1011975 is a reply to message #1011932] Wed, 20 February 2013 11:05 Go to previous messageGo to next message
Yes many to One should be possible.
The secret is the "@" operator to specify your input extent; See p76 of
the QVT spec.
Ed Willink
On 20/02/2013 15:56, Miriam Hundemer wrote:
> Hi all,
> (uml).
> Thanks a lot,
> Miriam
Re: "Many-Model to Model" transformation with qvto? [message #1012932 is a reply to message #1011975] Fri, 22 February 2013 08:33 Go to previous messageGo to next message
Hi Ed
you're not talking about chapter 8.1.18 "Advanced Features: dynamic definition and parallelism" when you say p76, are you? Because I could not find any "@" operator there... Sad
Could you be a little more specific and maybe tell me which chapter of the QVT spec you mean?
But tanks a lot for your quick answer!!!
Miriam
Re: "Many-Model to Model" transformation with qvto? [message #1012957 is a reply to message #1012932] Fri, 22 February 2013 09:13 Go to previous messageGo to next message
p76 of "Meta Object Facility (MOF) 2.0 Query/View/Transformation
Specification Version 1.1 Final Adopted Specification ptc/09-12-05" is
8.2.1.16 MappingParameter
NB Page numbers are those shown on the page, not those shown in a tool.
NB. There really aren't very many '@' characters to search for. I found
p76 for you by starting at the top.
Ed Willink
On 22/02/2013 13:33, Miriam Hundemer wrote:
> Hi Ed
> not find any "@" operator there... :( Could you be a little more
> Regards
> Miriam
Re: "Many-Model to Model" transformation with qvto? [message #1012978 is a reply to message #1012957] Fri, 22 February 2013 10:01 Go to previous messageGo to next message
Hi Ed;
There is a newer specification also numbered as 1.1 as the "ptc/09-12-05". It is from 2011 and it is available at the OMG website (http://www.omg.org/spec/QVT/) and its code is "formal/2011-01-01".
In this version, the MappingParameter is on page 94.
And yes, it is very strange and confusing!
Regards;
Re: "Many-Model to Model" transformation with qvto? [message #1013001 is a reply to message #1012978] Fri, 22 February 2013 10:40 Go to previous messageGo to next message
Ok,
now I've found the chapter you ment Ed, but as I use the specification Fabio mentioned above, it is indeed on page 94, sorry for the confusion.
But if I'm interpreting this right, the "@" is not exactly what I need. As I understand , the "@" is only used for the parameters of a mapping in order to specify the precise in or out model they "belong to". But the in and out models still have to be defined in the transformation declaration above and are fixed afterwards.
transformation T(in src:S, out dest1:D, out dest2:D);
mapping X::foo(inout Y@dest1) : Y@dest2;
// 'X' is a class of 'S' metamodel and 'Y' is a class of 'D' metamodel
Here, the inmodels src and the outmodels dest1 and dest2 are defined in the transformation declaration and used later as parameter type in the mapping operation.
Perhaps I didn't explain my problem properly:
What I would need in my project (I think) is kind of beeing able to have a list (of variable length) of in models in the transformation declaration because from one execution of the transformation to the next, it is possible that the number of in models (xml files) changes.
Is there something like the second example?
//transformation with more than one but fixed number of inmodels
transformation T1 (in inModel1:Metamodel, inModel2:Metamodel, out outModel:UML);
//transformation with variable number of inmodels
transformation T (<list_of_inModels>, out outModel:UML);
All of the inmodels will be of the same metamodel.
Re: &amp;amp;quot;Many-Model to Model&amp;amp;quot; transformation with qvto? [message #1013002 is a reply to message #1012978] Fri, 22 February 2013 10:36 Go to previous messageGo to next message
Sorry for the confusion. I should have known better.
The 1.1-Beta was the prevailing spec for so long, that I gave up looking
for the non-Beta.
Ed Willink
On 22/02/2013 15:01, Fabio L. S. wrote:
> Hi Ed;
> Regards;
Re: &amp;amp;quot;Many-Model to Model&amp;amp;quot; transformation with qvto? [message #1013029 is a reply to message #1013001] Fri, 22 February 2013 11:17 Go to previous message
If it's a variable number of models, I suggest creating a super-model
that references all the others.
Ed Willink
On 22/02/2013 15:40, Miriam Hundemer wrote:
> Ok,
> outModel:UML);
Previous Topic:Large Model, minor changes
Next Topic:[QVT] Calling QVT transformation from within java class
Current Time: Sun Jul 20 12:04:23 EDT 2025
Powered by FUDForum. Page generated in 0.04661 seconds
