Home » Language IDEs » Objectteams » "Object Teams Patch for JDT/Core" issue on update
"Object Teams Patch for JDT/Core" issue on update [message #983393] |
Tue, 13 November 2012 17:33  |
When checking for updates, it says :"Object Teams Patch for JDT/Core" is not applicable to the current configuration and will not be installed.
Object Teams Patch for JDT/Core version 2.0.1.201109101025 Id: org.eclipse.objectteams.otdt.core.patch.feature.group
My environment:
Windows 7 Pro, Java 1.6.0_37
Eclipse Indigo Service Release 2 (Eclipse IDE for C/C++ Developers)
Build id: 20120216-1857
Anyone has idea on what it's talking about? And any solution to skip/fix that component?
Thanks in advance.
Re: "Object Teams Patch for JDT/Core" issue on update [message #990346 is a reply to message #984380] |
Wed, 12 December 2012 00:08   |
Hi Stephan,
Thanks for your reply.
Following your indications, I found that the "Object Teams Patch for JDT/Core" installed in my Indigo is version 2.0.2.201202051448 (by checking installation details), not 2.0.1.201109101025 .
Then I wonder why it shows the earlier 2.0.1.x version blocking my update when I click "Check for Updates" ?
I don't want to upgrade from Indigo to Juno, while just intend to update some existing plugins based on Indigo. My indigo has Java/PHP/C++ plugins mixed to develop different things.
I had a test: Firstly, uninstall "Object Teams Patch for JDT/Core", and secondly run "Check for Updates", it shows me to install that patch again, without other choice. And then I have to installed it, and then "Check for Updates", it again tells me that original error, blocking me from updating any other plugins.
So now I have no idea how to work around this "Patch" plugin for updating other plugins.
Any hint would be greatly appreciated.
cheers,
Jackey
Re: "Object Teams Patch for JDT/Core" issue on update [message #1011496 is a reply to message #1011272] |
Tue, 19 February 2013 11:34   |
All this is strange.
Usually I download and install Eclipse directly from Eclipse.org, and I don't see much advantage in using Ubuntu packages instead.
Still, running on Ubuntu 12.04 myself I just tried it that way.
First Eclipse couldn't find SWT binaries [1].
After fixing that and adding the indigo update site into Eclipse Indigo (looks indeed inconsistent), I could do several rounds of updates with no problem. I think the second update suggested to install the Object Teams patch, and it installed without a problem.
Wait, as I'm speaking, on trying the forth round or so of updating, I can see the problem.
At this point I have the following situation:
- installed is Eclipse Java Development Tools 3.7.2.v20120120-1414-.....
- installed is Object Teams Patch for JDT/Core 2.0.1.201109101025
- proposed for update is Object Teams Patch for JDT/Core 2.0.2.201202051448
- error is: "Object Teams Patch for JDT/Core" is not applicable to the current configuration and will not be installed.
Observations:
- (1) and (2) should not be compatible (although installing this worked OK).
- (1) and (3) should be compatible
- While displaying the error message, the Detail message is no longer shown, which normally reads:
This feature is NOT a regular update of the JDT, but REPLACES the
org.eclipse.jdt.core plugin by the corresponding version for Object Teams.
This change makes the JDT Core capable to handle OT/J code.
Eclipse p2 has several known bugs that amount to the fact, that normally patch features cannot be installed into a shared install for which the user has no write permission. Partly I'm surprised to see it work in this situation at all.
I happen to know that Pascal Rapicault is right now re-writing part of p2 in order to improve the situation for shared installes (including better error messages, migration strategies etc.) - this will go into Eclipse 4.3 (Kepler).
I will be a while before these fixes show up in Ubuntu.
Finally I tried to install the full Object Teams Development Tooling. Again installing seemed to work alright, only when I wanted to start working in the Object Teams perspective did I find that neither this nor the Java perspective were available. I.e., something claimed that installation was successful, where in fact it had broken the install.
Advice:
- If you want to use Object Teams, please install from an original Eclipse package from Eclipse.org.
- If Object Teams came to you only by accident, please excuse, simply uncheck this update when it is offered
- and in that case I still hope, you'll find some time to read about the coolness of Object Teams [2] and come back later
cheers,
Stephan
[1] https://bugs.launchpad.net/ubuntu/+source/swt-gtk/+bug/975560
[2] http://wiki.eclipse.org/OTJ_Primer
Current Time: Sun Jul 20 18:40:43 EDT 2025
Powered by FUDForum. Page generated in 0.04784 seconds
