xtext editor with rcp app [message #1010830] |
Mon, 18 February 2013 05:02  |
hi
i'm trying to setup a rcp for my xtext dsl, when i run the first time it works, but if i tried to restart my rcp app after that i created a mydsl file it raises an exception, i figure out that if i clear the workspace before to start my rcp app it works,
any suggestion?
at org.eclipse.ui.actions.RetargetAction.partClosed(RetargetAction.java:164)
at org.eclipse.ui.internal.PartService$3.run(PartService.java:98)
at org.eclipse.ui.internal.PartService.partClosed(PartService.java:96)
at org.eclipse.ui.internal.WorkbenchPage$17.run(WorkbenchPage.java:4390)
at org.eclipse.ui.internal.WorkbenchPage.firePartClosed(WorkbenchPage.java:4388)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart$1.handleEvent(CompatibilityPart.java:99)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4291)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:187)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:81)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:57)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.UIElementImpl.setWidget(UIElementImpl.java:248)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.unbindWidget(SWTPartRenderer.java:114)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.disposeWidget(SWTPartRenderer.java:135)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.disposeWidget(ContributedPartRenderer.java:285)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeRemoveGui(PartRenderingEngine.java:840)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$3(PartRenderingEngine.java:768)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$8.run(PartRenderingEngine.java:763)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.removeGui(PartRenderingEngine.java:748)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeRemoveGui(PartRenderingEngine.java:794)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeRemoveGui(PartRenderingEngine.java:801)
at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.disposeWidget(ElementReferenceRenderer.java:122)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.stop(PartRenderingEngine.java:1074)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:1118)
at org.eclipse.ui.internal.Workbench.access$16(Workbench.java:998)
at org.eclipse.ui.internal.Workbench$17.run(Workbench.java:1179)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1177)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1150)
at org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchWindow.java:1155)
at org.eclipse.ui.internal.WorkbenchWindow.access$16(WorkbenchWindow.java:1135)
at org.eclipse.ui.internal.WorkbenchWindow$10.run(WorkbenchWindow.java:1184)
at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindow.java:1182)
at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindow.java:1194)
at org.eclipse.ui.internal.WorkbenchWindow$6.close(WorkbenchWindow.java:441)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer$10.shellClosed(WBWRenderer.java:562)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:98)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1276)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1300)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1285)
at org.eclipse.swt.widgets.Shell.closeWidget(Shell.java:617)
at org.eclipse.swt.widgets.Shell.gtk_delete_event(Shell.java:1191)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1750)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:5116)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4369)
at org.eclipse.swt.internal.gtk.OS._gtk_main_do_event(Native Method)
at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(OS.java:8295)
at org.eclipse.swt.widgets.Display.eventProc(Display.java:1192)
at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Native Method)
at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS.java:2332)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3177)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:585)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
at eu.posecco.rcpapplication.Application.start(Application.java:120)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Re: xtext editor with rcp app [message #1010897 is a reply to message #1010830] |
Mon, 18 February 2013 07:42  |
I don't see xtext on the stack.
Did you exit the rcp app cleanly? These things usually mean the
persisted state of your workspace is corrupt, which mostly happens
because the app crashed or was killed the last time.
Am 18.02.13 11:02, schrieb mark j:
> hi i'm trying to setup a rcp for my xtext dsl, when i run the first time
> workspace before to start my rcp app it works, any suggestion?
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> Method)
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> at
> at
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
FUDForum. Page generated in 1.23198 seconds
