Home » Modeling » TMF (Xtext) » Empty rule
Empty rule [message #1010122] Sat, 16 February 2013 11:03 Go to next message
Hi.
How can I define grammars with empty rules in Xtext?
For example:
grammar ir.ut.ece.MathExpComp_1 with org.eclipse.xtext.common.Terminals
generate mathExpComp_1 "http://www.ut.ir/ece/MathExpComp_1"
E:
	T Ep
E1P:
	'+' T Ep
Ep:
T:
	F Tp
T1p:
	'*' F Tp
Tp: // Empty rule
F:
	value=INT
Bests,
Pooyan
Re: Empty rule [message #1010126 is a reply to message #1010122] Sat, 16 February 2013 11:12 Go to previous messageGo to next message
HI,
you/have to assign things in xtext.and you can use cardinalities.
You may have a look at
http://blog.efftinge.de/2010/08/parsing-expressions-with-xtext.html
Re: Empty rule [message #1010131 is a reply to message #1010126] Sat, 16 February 2013 11:32 Go to previous messageGo to next message
Dear Christian,
Hi.
I appreciate your time and your kind answer.
The mathematical expression was just to show the problem that I have been faced. I have some problem with inherited attributes in xtext grammar.
I am developing a DSL which it's grammar contains some empty parsing elements (epsilon rules).
Is it possible to write such grammars in Xtext?
Bests,
Pooyan
Re: Empty rule [message #1010133 is a reply to message #1010131] Sat, 16 February 2013 11:36 Go to previous messageGo to next message
hi
can you post the real example?
~Christian
Re: Empty rule [message #1010233 is a reply to message #1010131] Sat, 16 February 2013 19:01 Go to previous message
On 2013-16-02 17:32, Pooyan Behnamghader wrote:
> Dear Christian,
> Hi.
In some grammar languages you write something like
R : // empty
| something
In Xtext, this is done with cardinality - i.e:
R : something ?
Which means R contains an optional something (since it is optional,
"empty"/"nothing" is also valid at this position.
Does that answer your question?
- henrik
Previous Topic:Xtend2: extended type-based collection filters
Next Topic:Skipping validations of features from EMF Model
Current Time: Sat Jul 19 07:49:27 EDT 2025
Powered by FUDForum. Page generated in 0.05426 seconds
