Home » Modeling » Papyrus » [Beginner] Can't find Java types
[Beginner] Can't find Java types [message #1009736] Fri, 15 February 2013 11:02 Go to next message
Hi all,
I'm testing Papyrus (0.9.1). I'm trying to create a class diagram. I created a class, added a property but I can't assign the java.lang.String type to that property.
Maybe I need to install some additional plugin?
Configure something?
Thanks for your help.
-- Arnaud.
Re: [Beginner] Can't find Java types [message #1009815 is a reply to message #1009736] Fri, 15 February 2013 14:18 Go to previous messageGo to next message
Hi, Arnaud,
You need to import a library of types. Select the Model (root package)
in the Model Explorer, right click, and Import -> Registered Package.
The UML Primitive Types library has a String type; maybe the Java
library does, too, (though it's not a Java "primitive").
HTH,
Christian
On 2013-02-15 16:02:29 +0000, avandyck@xxxxxxxx Mising name said:
> Hi all,
> -- Arnaud.
Re: [Beginner] Can't find Java types [message #1015253 is a reply to message #1009815] Wed, 27 February 2013 16:49 Go to previous messageGo to next message
Hi there,
the library you guys are talking about is called "JavaPrimitiveTypes" and does not contain the "String" type.
Cheers!
Re: [Beginner] Can't find Java types [message #1016144 is a reply to message #1015253] Tue, 05 March 2013 04:12 Go to previous message
Thanks for your answers. Is there a way to import packages from a library? From a jre or any other library?
Previous Topic:Call menu action
Next Topic:Allocation Table: Unresolved reference '/1
Current Time: Sat Jul 19 09:46:11 EDT 2025
Powered by FUDForum. Page generated in 0.04044 seconds
