Home » Archived » Test and Performance Tools Platform (TPTP) » Launching process and not stopping them
Launching process and not stopping them [message #100890] Wed, 13 June 2007 12:42 Go to next message
Originally posted by: cguibert.axway.com
Hello
I would like to start external applications in my TestSuite but not
necessarly stop them
In all the test I did, each time eclipse is blocked at 93 % and the
TestSuite only finishes when I manually kill the external process.
Does anyone already have this problem ? Find a workaround ? Or is this
definitively not possible to do so ?
Thanks for your help
Re: Launching process and not stopping them [message #100961 is a reply to message #100890] Thu, 14 June 2007 08:20 Go to previous messageGo to next message
Hi Guibert,
What version of TPTP are you using?
You can find an example of starting external application in
org.eclipse.tptp.platform.execution.samples.TPTPProcess.java
Igor
Re: Launching process and not stopping them [message #100975 is a reply to message #100961] Thu, 14 June 2007 13:54 Go to previous message
Igor Alelekov wrote:
> Hi Guibert,
> Regards,
> Igor
Dear Igor
Thanks for your answer
I'm using TPTP 4.2.1
I tested the code you sent me and it seems to work fine.
However, I have one last concern: the sample is related to the TPTP
frameword (I mean, I'm doing a connection to the RA).
Whereas is my case, I just want to use TPTP for doing tests. So my
TestSuite is supposed to be deployed on the remote server and I'm not sure
I'm supposed to do another connection to the RA.
Since I'm a new is using TPTP for testing, maybe I understood the
architecture incorretly.
So you confirm that this is the normal correct way of executing an
external application in the TestSuite ? And that I'm not using a
workaround or something that will no longer be supported in the next
released ?
Thanks again for your help.
Previous Topic:Execution flow does not show anything
Next Topic:TPTP AGR problem on PVCS plug-in
Current Time: Sat Jul 19 10:22:42 EDT 2025
Powered by FUDForum. Page generated in 0.04474 seconds
