Re: Starting SWT AUT [message #690977 is a reply to message #690958] |
Thu, 30 June 2011 09:49   |
I have tried to do something similar to what you suggest, but mine works.
The difference seems to be that I have a few more lines at the start of my batch file:
D:
CD \Folder\Where\JAR\File\Is
"C:\Program Files\Java\jdk1.6.0_26\bin\javaw.exe" -jar name_of_jar_file.jar %1 %2 %3
As long as all the paths are known, this should work.
I have not managed to get the same error as you have, but I have others.
For example if deliberately specify the wrong jar file (typo, jar file not in class path because batch file started from another drive and folder...) I get the following error message in the client log:
[Connection.ReaderThread:Socket[addr=/myIP,port=60000,localport=63748]] ERROR o.e.j.c.c.c.StartAUTServerStateCommand - AUTServer could not start: invalid arguments
Also if I deliberately make my Java application fail and return error code -1 using System.exit(-1), I get an error message in the standalone ITE saying:
5009: AUT start failed
Establishing connection to AUT failed.
Please check the AUT configuration.
I also get an error message in the Client log:
[Connection.ReaderThread:Socket[addr=/myIP,port=60000,localport=64068]] ERROR o.e.j.c.c.c.StartAUTServerStateCommand - AUTServer could not start: unknown AUTServer exit code: '-1'
This all seems to work as designed and be rather good at error reporting
[Updated on: Thu, 30 June 2011 10:24] by Moderator
Re: Starting SWT AUT [message #1699002 is a reply to message #689868] |
Fri, 19 June 2015 08:10   |
I have what seems to be exactly this problem (persistent 5009: AUT start failed), using the Jubula Function Testing plugin 2.3.0.201406030848 downloaded via the eclipse marketplace. (I have Eclipse Juno, Service Release 2 build ID 3.0.201406030848, and am running on Ubuntu Precise.) I am using the embedded AUT.
There appears to be no information in the logs, the help->client log and help->aut log menu items do nothing, and in ~/.jubula/logs I find only old log files for aut_agent.log and client.log (with errors from my previous efforts, no doubt)
However, checking the process information for eclipse, I see it is writing in ~/.xsession-errors, and there's a clue there (see below). Essentially it looks like there's an exception killing the AUT, "NoClassDefFoundError: org/apache/log4j/Level". Note this is not a ClassNotFoundException. The SLF4J message is allegedly just a warning, I am not sure if it is relevant.
Elsewhere in the .xsession-errors file, I also see the error (also below) "No appenders could be found for logger (org.eclipse.jubula.client.core.ClientTestImpl)."
Being bold, Iguessed the SLG4J message *is* related, so I moved the older jar mentioned (org.slf4j.impl.log4j12_1.7.2.v20131105-2200.jar) away, and restarted eclipse. Now the AUT fails, but again the error appears in .xsession-errors, and for a different error, one created by my application. Now that error is one I know how to fix, and the next time I run the AUT, the application starts!
So, the important thing seems to be to remember to look in .xsession-errors (or an equivalent), as the Log4J initialisation can fail. In my case, SLF4J seems to have two bindings, and the wrong one is chosen. Maybe this will help someone else.
AUT:SLF4J: Class path contains multiple SLF4J bindings.
AUT:SLF4J: Found binding in [jar:file:/home/nick/i/eclipse/plugins/org.slf4j.impl.log4j12_1.7.2.v20131105-2200.jar!/org/slf4j/impl/StaticLoggerBinder.class]
AUT:SLF4J: Found binding in [jar:file:/home/nick/i/eclipse/plugins/ch.qos.logback.slf4j_1.0.7.v20121108-1250.jar!/org/slf4j/impl/StaticLoggerBinder.class]
AUT:SLF4J: See http //www.slf4j.org/codes.html#multiple_bindings for an explanation.
AUT:Failed to instantiate SLF4J LoggerFactory
AUT:Reported exception:
AUT:java.lang.NoClassDefFoundError: org/apache/log4j/Level
AUT: at org.slf4j.LoggerFactory.bind(LoggerFactory.java:128)
AUT: at org.slf4j.LoggerFactory.performInitialization(LoggerFactory.java:107)
AUT: at org.slf4j.LoggerFactory.getILoggerFactory(LoggerFactory.java:295)
AUT: at org.slf4j.LoggerFactory.getLogger(LoggerFactory.java:269)
AUT: at org.slf4j.LoggerFactory.getLogger(LoggerFactory.java:281)
AUT: at org.eclipse.jubula.rc.common.AUTServer.<clinit>(AUTServer.java:78)
AUT: at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
AUT: at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
AUT: at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
AUT: at java.lang.reflect.Method.invoke(Method.java:606)
AUT: at org.eclipse.jubula.rc.common.AutServerLauncher.main(AutServerLauncher.java:96)
AUT:Caused by: java.lang.ClassNotFoundExceptioAUT:SLF4J: Class path contains multiple SLF4J bindings.
AUT:Caused by: java.lang.ClassNotFoundException: org.apache.log4j.Level
AUT: at java.net.URLClassLoader$1.run(URLClassLoader.java:366)
AUT: at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
AUT: at java.security.AccessController.doPrivileged(Native Method)
AUT: at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
AUT: at java.lang.ClassLoader.loadClass(ClassLoader.java:425)
AUT: at org.eclipse.jubula.rc.common.AutServerLauncher$UrlDefaultClassLoader.loadClass(AutServerLauncher.java:228)
AUT: at org.eclipse.jubula.rc.common.AutServerLauncher$UrlDefaultClassLoader.loadClass(AutServerLauncher.java:246)
AUT: ... 11 more
AUT:Exception in thread "main" java.lang.NoClassDefFoundError: org/apache/log4j/Level
AUT: ... 11 more
plasma-desktop(2590)/plasma StatusNotifierItemSource::refreshCallback: DBusMenu disabled for this application
(process:2590): libindicate-WARNING **: Unable to get property data: GDBus.Error:com.canonical.indicate.NO_SUCH_PROPERTY: Indicator 146 has no property named 'icon'
(process:2590): libindicate-WARNING **: Unable to get property data: GDBus.Error:com.canonical.indicate.NO_SUCH_PROPERTY: Indicator 146 has no property named 'time'
(process:2590): libindicate-WARNING **: Unable to get property data: GDBus.Error:com.canonical.indicate.NO_SUCH_PROPERTY: Indicator 146 has no property named 'draw-attention'
(process:2590): libindicate-WARNING **: Unable to get property data: GDBus.Error:com.canonical.indicate.NO_SUCH_PROPERTY: Indicator 147 has no property named 'icon'
(process:2590): libindicate-WARNING **: Unable to get property data: GDBus.Error:com.canonical.indicate.NO_SUCH_PROPERTY: Indicator 147 has no property named 'time'
(process:2590): libindicate-WARNING **: Unable to get property data: GDBus.Error:com.canonical.indicate.NO_SUCH_PROPERTY: Indicator 147 has no property named 'draw-attention'
AUT: ... 11 more
AUT: ... 11 more
SLF4J: Found binding in [bundleresource://2381.fwk295932193:1/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [bundleresource://2381.fwk295932193:2/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Actual binding is of type [org.slf4j.impl.Log4jLoggerFactory]
log4j:WARN No appenders could be found for logger (org.eclipse.jubula.client.core.ClientTestImpl).
log4j:WARN Please initialize the log4j system properly.
FUDForum. Page generated in 0.29598 seconds
