Re: Grammar Mixins [message #1007975 is a reply to message #1007459] |
Fri, 08 February 2013 02:17   |
please make sure that the runtime plugin for the definitions language
exports all its packages, esp. the package
org.xtext.example.definitions.services
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 05.02.13 23:39, schrieb junior developer:
> Hello all ,
> I work grammar inheritance and ı take an error I think this error about
> path (egisterGeneratedEPackage ,registerGenModelFile)but I dont solved
> it :( I try this example from xtext documentation.Add a plug-in
> dependency in the MANIFEST.MF.(add required path in the
> GenerateUsages.MWE2).I generated language artifacts I do not take an
> error when debuging.I take ANTLR error , so that I do not create useges
> extension.Error is in the InternalUsagesParser class(UI package).How
> solve this problem? ,please help me .
> Error:The method getRuleAAccess() from the type UsagesGrammarAccess
> refers to the missing type RuleAElements- The type
> org.xtext.example.definitions.services.DefinitionsGrammarAccess$RuleAElements
> cannot be resolved. It is indirectly referenced from required .class files
> My supergrammar:
> grammar org.xtext.example.definitions.Definitions with
> org.eclipse.xtext.common.Terminals
> generate definitions "http://www.xtext.org/example/definitions/Definitions"
> RuleA : "a" stuff=RuleB;
> RuleB : "{" name=ID "}";
> My subgrammar :
> grammar org.xtext.example.usages.Usages with
> generate usages "http://www.xtext.org/example/usages/Usages"
> import "http://www.eclipse.org/emf/2002/Ecore" as ecore
> Model : (ruleAs+=RuleA)*;
> RuleB : '[' name=ID ']'; //overriding
Re: Grammar Mixins [message #1744557 is a reply to message #1008211] |
Wed, 28 September 2016 05:11  |
junior developer wrote on Mon, 11 February 2013 13:41My problem is solved.
Could you please let us know how you solved the problem? I'm struggling with the same issue right now.
EDIT: I just figured out the solution. The plug-in of the super language needs to be added to the manifest.mf file of the .ide project of the sub language.
[Updated on: Wed, 28 September 2016 05:30] by Moderator
FUDForum. Page generated in 0.06539 seconds
