chart Zooming [message #1008340] |
Mon, 11 February 2013 22:19  |
Hello all,
I am using the BIRT charting engine in an RCP application where the chart
is rendered in Swing . I would like to be able to zoom in to the chart by using the mouse to draw a rectangle
around the data of interest. Is there a way to add interactivity to the
chart that would return the corresponding label values of the xmin, ymin, xmax, ymax of the rectangle ?
I need those label values to fix the max and min scale value to zoom the plot.
Savitha
Re: chart Zooming [message #1008734 is a reply to message #1008540] |
Wed, 13 February 2013 13:41   |
Hello Jason,
Am adding trigger to the plot(chart.getPlot().getTriggers().addTrigger(.....) ).
Looks like it is not working. If you could give suggestion on how to make this work, it would be great.
So, I added mouseListener to the JPanel and performing the necessary Logic in MousePressed and Released.
I got access to the datapointhints from GeneratedChartState object and is working fine so far, but if you could suggest a better way of doing this, it'll be helpful.
Finally, I want to draw the rectangle(rubber band zooming) on the plot while zooming. I saw your previous post
where you have implemented in javascript. If you could point me to some material on how to do it in swing, it would be great.
Savitha
[Updated on: Wed, 13 February 2013 14:18] by Moderator
FUDForum. Page generated in 0.06246 seconds
