Home » Modeling » TMF (Xtext) » Plugin editor fails to load(works OK in runtime eclipse, fails in tycho-generated plugin)
Plugin editor fails to load [message #1008329] Mon, 11 February 2013 18:03
Having some problems with a tycho build. Generated editor works OK if launched as runtime eclipse instance. Tycho build runs OK and generates p2 site, from which the editor plugin can be installed into a second eclipse instance.
However: if I try to edit a dsl file in the second instance it fails to load with:
Plug-in com.mycompany.mylang.ui was unable to load class com.mycompany.mylang.ui.MyLangExecutableExtensionFactory.
Have confirmed the class is in the plugin jar; not quite sure where to look next.
Any suggestions?
Thanks.
Previous Topic:xtend-maven-plugin has no outputs
Next Topic:Global scope and resolving Maven/Plugin dependencies
Current Time: Sat Jul 19 11:22:11 EDT 2025
Powered by FUDForum. Page generated in 0.04345 seconds
