Home » Modeling » TMF (Xtext) » Grammar Mixins
Grammar Mixins [message #1007459] Tue, 05 February 2013 17:39 Go to next message
Hello all ,
I work grammar inheritance and ı take an error I think this error about path (egisterGeneratedEPackage ,registerGenModelFile)but I dont solved it Sad I try this example from xtext documentation.Add a plug-in dependency in the MANIFEST.MF.(add required path in the GenerateUsages.MWE2).I generated language artifacts I do not take an error when debuging.I take ANTLR error , so that I do not create useges extension.Error is in the InternalUsagesParser class(UI package).How solve this problem? ,please help me .
Error:The method getRuleAAccess() from the type UsagesGrammarAccess refers to the missing type RuleAElements- The type org.xtext.example.definitions.services.DefinitionsGrammarAccess$RuleAElements cannot be resolved. It is indirectly referenced from required .class files
My supergrammar:
grammar org.xtext.example.definitions.Definitions with
org.eclipse.xtext.common.Terminals
generate definitions "http://www.xtext.org/example/definitions/Definitions"
RuleA : "a" stuff=RuleB;
RuleB : "{" name=ID "}";
My subgrammar :
grammar org.xtext.example.usages.Usages with org.xtext.example.definitions.Definitions
generate usages "http://www.xtext.org/example/usages/Usages"
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
Model : (ruleAs+=RuleA)*;
RuleB : '[' name=ID ']'; //overriding
Re: Grammar Mixins [message #1007975 is a reply to message #1007459] Fri, 08 February 2013 02:17 Go to previous messageGo to next message
please make sure that the runtime plugin for the definitions language
exports all its packages, esp. the package
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 05.02.13 23:39, schrieb junior developer:
> Hello all ,
> it :( I try this example from xtext documentation.Add a plug-in
> My supergrammar:
> My subgrammar :
Re: Grammar Mixins [message #1008129 is a reply to message #1007975] Sun, 10 February 2013 07:28 Go to previous messageGo to next message
Hi Sebastian,
When I generate the language code, I receive previously mentioned error for InternalUsagesParser class in org.xtext.example.usages.ui.contentassist.antlr.internal package. The error occures in the grammarAccess.getRuleAAccess() function call of the automatically generated ruleRuleA() function. Interestingly the project works without any problem. I write programs in the editor and I don't take any error, e.g. I can use overriding rule.
Could you possibly introduce me a solution to resolve this error?
Best regards
[Updated on: Sun, 10 February 2013 07:31] by Moderator
Re: Grammar Mixins [message #1008130 is a reply to message #1008129] Sun, 10 February 2013 09:14 Go to previous messageGo to next message
simply adding a dep (manifest.mf) from subgrammar.ui to supergrammar.ui doesnt work
Re: Grammar Mixins [message #1008211 is a reply to message #1008130] Mon, 11 February 2013 08:41 Go to previous messageGo to next message
Hi Christian,
My problem is solved.My other problem is abouth Automatic Validation error and warning changes.I can write my own mistakes rather than automatic generated syntax errors.Such as,instead of mismatched input '<EOF>' expecting 'something' ,I can write own error definition automatic validation error and warning.How can I do it ?Is it possible to accomplish this?
Best Regards
Re: Grammar Mixins [message #1008252 is a reply to message #1008211] Mon, 11 February 2013 13:29 Go to previous messageGo to next message
HI,
the hook for that is org.eclipse.xtext.parser.antlr.SyntaxErrorMessageProvider
Re: Grammar Mixins [message #1008658 is a reply to message #1008252] Wed, 13 February 2013 08:17 Go to previous messageGo to next message
Hi Christian,
I works on Automatic Validation customize.Which package is used for create SyntaxErrorMessageProviderCustom xtend class ?
I create SyntaxErrorMessageProviderCustom xtend class that is extended from SyntaxErrorMessageProvider, under the org.xtext.example.mydsl package and register it in the MyDslRuntimeModule.java
public Class<? extends SyntaxErrorMessageProvider > bindIEObjectHoverProvider() {
return SyntaxErrorMessageProviderCustom.class;
But My grammar extension did not occur at the run time .I'm so confused. I wonder ,create java class under the org.xtext.example.mydsl.ui package and create interface such as Hover in your blog( http://christiandietrich.wordpress.com/2011/07/16/hover-support-in-xtext-2-0-tutorial/ ).I hope my problem is clear.
Best Regards
Re: Grammar Mixins [message #1008672 is a reply to message #1008658] Wed, 13 February 2013 09:24 Go to previous messageGo to next message
i dont get your point. the package doesnt matter, the binding counts
public Class<? extends org.eclipse.xtext.parser.antlr.ISyntaxErrorMessageProvider> bindISyntaxErrorMessageProvider() {
return MySyntaxErrorMessageProvider.class;
you may bind it in the runtimemodule or in the ui module only depending on your needs
Re: Grammar Mixins [message #1008699 is a reply to message #1008672] Wed, 13 February 2013 11:01 Go to previous messageGo to next message
Hi Christian,
Thank you very much ,run my program
I create Xtend class below :
package org.xtext.example.mydsl.ui
import org.eclipse.xtext.parser.antlr.SyntaxErrorMessageProvider
import org.eclipse.xtext.IGrammarAccess
import javax.inject.Inject
import org.eclipse.xtext.parser.antlr.ISyntaxErrorMessageProvider$IParserErrorContext
import org.eclipse.xtext.nodemodel.SyntaxErrorMessage
import org.eclipse.xtext.GrammarUtil
class MyDslSyntaxErrorMessageProvider extends SyntaxErrorMessageProvider{
public static val String USED_RESERVED_KEYWORD = "USED_RESERVED_KEYWORD"
@Inject IGrammarAccess grammarAccess
override getSyntaxErrorMessage(IParserErrorContext context) {
val unexpectedText = context?.recognitionException?.token?.text
if (GrammarUtil::getAllKeywords(grammarAccess.getGrammar()).contains(unexpectedText)) {
println(context.defaultMessage)
return new SyntaxErrorMessage('''
"«unexpectedText»" is a reserved keyword which is not allowed as Identifier.
"^«unexpectedText»".''',
USED_RESERVED_KEYWORD)
super.getSyntaxErrorMessage(context)
And then I bind it MyDslUiModule.java ,solved my problem
public Class<? extends ISyntaxErrorMessageProvider> bindISyntaxErrorMessageProvider() {
return MyDslSyntaxErrorMessageProvider.class;
the code runs but I done it with xtend class . I wonder if I do it with java code .I want to create java class .I do not find enough example with java code.
Best Regards
Re: Grammar Mixins [message #1008702 is a reply to message #1008699] Wed, 13 February 2013 11:07 Go to previous messageGo to next message
Hi I still do not understand your problem and what it does have to do
with Xtend
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: Grammar Mixins [message #1009455 is a reply to message #1008702] Fri, 15 February 2013 02:09 Go to previous messageGo to next message
Hi Christian,
I want to doing Automatic Validation customize with java class.In the previous example ,I use xtend class and I write not pure java code.But I want to write pure java in the same example(above).I do not find enough example from the net.Such as http://henrik-eclipse.blogspot.com/2010/05/implementing-date-support-with-quickfix.html.
Re: Grammar Mixins [message #1009459 is a reply to message #1009455] Fri, 15 February 2013 02:19 Go to previous messageGo to next message
Hi I still don't get your problem
@Check
public void check whatever(MyType my type){}
or dont you know how to write the SyntaxErrorMessageProvider in java.
if so what exactly is the problem?
[Updated on: Fri, 15 February 2013 02:55] by Moderator
Re: Grammar Mixins [message #1009555 is a reply to message #1009459] Fri, 15 February 2013 05:05 Go to previous messageGo to next message
Hi Christian ,
Like the function in the code above, I'd like to write it in Java. My problem in this case is, that don't found enough examples how to write it in Java syntax. I want to write an automatic validation code like in the custom validation code. Can you help me out with that in Java or can you give me some hints?
Best Regards
Re: Grammar Mixins [message #1009609 is a reply to message #1009555] Fri, 15 February 2013 06:32 Go to previous messageGo to next message
HI,
sorry i do not get it? i cannot teach you how to write java
import org.eclipse.xtext.GrammarUtil;
import org.eclipse.xtext.IGrammarAccess;
import org.eclipse.xtext.nodemodel.SyntaxErrorMessage;
import org.eclipse.xtext.parser.antlr.SyntaxErrorMessageProvider;
import com.google.inject.Inject;
public class MyDslSyntaxErrorMessageProvider extends SyntaxErrorMessageProvider {
	public static final String USED_RESERVED_KEYWORD = "USED_RESERVED_KEYWORD";
	@Inject
	IGrammarAccess grammarAccess;
	public SyntaxErrorMessage getSyntaxErrorMessage(IParserErrorContext context) {
		if (context.getRecognitionException() != null
				&& context.getRecognitionException().token != null) {
			String unexpectedText = context.getRecognitionException().token
					.getText();
			if (GrammarUtil.getAllKeywords(grammarAccess.getGrammar())
						unexpectedText
								+ "  is a reserved keyword which is not allowed as Identifier",
						USED_RESERVED_KEYWORD);
		return super.getSyntaxErrorMessage(context);
Re: Grammar Mixins [message #1010069 is a reply to message #1009609] Sat, 16 February 2013 07:44 Go to previous messageGo to next message
Hi Christian,
Thank you for your help.I understand java syntax.I prefer to java code for Automatic Validation
Re: Grammar Mixins [message #1010074 is a reply to message #1010069] Sat, 16 February 2013 08:00 Go to previous messageGo to next message
I still do not understand what your actual question is?
Re: Grammar Mixins [message #1010716 is a reply to message #1010074] Mon, 18 February 2013 00:01 Go to previous messageGo to next message
Hi Christian,
My problem is to change default automatic validation error and warning messages and looking for a general solution how to do that.
I've got an example written in xtend-class (see below). I want to extend this code. For different or existing automatic validation error and warning messages I want to add custom messages. For example, I get for Cross-reference an error message ** Couldn't resolve reference to Name 'something' ** which is an automatic validation error, so I want to add or overide with my own code to get my error message something like that ** You cannot call 'something' **. Which functions do I need to realize that and where should I add this to existing keywords. I didn't have found enough sources to get this run, can you give me a hint how to realise it?
package org.xtext.example.mydsl1.ui;
public class MyDsl1SyntaxErrorMessageProvider extends SyntaxErrorMessageProvider {
	@Inject
/* I want to change Cross Reference Default Error Message:Couldn't resolve reference to Name 'something'... in my own custom message  */
		if (context.getRecognitionException() != null && context.getRecognitionException().token != null) {
			String unexpectedText = context.getRecognitionException().token.getText();
			if(GrammarUtil.getAllKeywords(grammarAccess.getGrammar()).contains(unexpectedText)) {
	return new SyntaxErrorMessage( "is a reserved keyword which is not allowed as Identifier",USED_RESERVED_KEYWORD);//changed Automatic validation (mismatched input //'Hello' expecting RULE_ID)
[Updated on: Mon, 18 February 2013 02:41] by Moderator
Re: Grammar Mixins [message #1010761 is a reply to message #1010716] Mon, 18 February 2013 02:42 Go to previous messageGo to next message
As said before: you have to do if else in the syntax error message
provider .
Re: Grammar Mixins [message #1011068 is a reply to message #1010761] Mon, 18 February 2013 14:40 Go to previous messageGo to next message
Hi Christian,
I did with else if. Thank you very much. Beside that I couldn't override the semantic error messages. I couldn't change with the SyntaxErrorMessageProvider class the "Couldn't resolve reference" default automatic validation message in the code below. Do I use the wrong class for that or do I need a different class to successful?
//public static final String USED_RESERVED_KEYWORD = "USED_RESERVED_KEYWORD";
//public static String INCOMPLETE_UNORDERED_GROUP = "INCOMPLETE_UNORDERED_GROUP";
@Inject
if (context.getDefaultMessage().startsWith("missing ")){
return new SyntaxErrorMessage( "missing error ",null);
else if(context.getDefaultMessage().startsWith("extraneous input ")){
return new SyntaxErrorMessage( "ID incorrect ",null);
else if(context.getDefaultMessage().startsWith("Couldn't resolve reference")) //for cross references
return new SyntaxErrorMessage( "incorrect reference variable ",null);//Default error is not change with this error
Best Regards
Re: Grammar Mixins [message #1011081 is a reply to message #1011068] Mon, 18 February 2013 15:17 Go to previous messageGo to next message
i strony recommend you to use the debugger to see what is in the context in certain situations
Re: Grammar Mixins [message #1011104 is a reply to message #1011081] Mon, 18 February 2013 16:30 Go to previous messageGo to next message
P.S: regarding the linking error you may hook into org.eclipse.xtext.linking.impl.LinkingDiagnosticMessageProvider
Re: Grammar Mixins [message #1744557 is a reply to message #1008211] Wed, 28 September 2016 05:11 Go to previous message
junior developer wrote on Mon, 11 February 2013 13:41
Could you please let us know how you solved the problem? I'm struggling with the same issue right now.
EDIT: I just figured out the solution. The plug-in of the super language needs to be added to the manifest.mf file of the .ide project of the sub language.
[Updated on: Wed, 28 September 2016 05:30] by Moderator
Previous Topic:xtext rules starts at new line
Next Topic:Embedded Xtext editor slects all text after using updateModel
Current Time: Sun Jul 20 08:14:09 EDT 2025
Powered by FUDForum. Page generated in 0.21540 seconds
