Home » Modeling » TMF (Xtext) » Using multiple OutputConfigurations with an JvmModelInferrer
Using multiple OutputConfigurations with an JvmModelInferrer [message #928660] Sun, 30 September 2012 17:37 Go to next message
I would like to have multiple outlets (IOutputConfiguration) and choose, which classes goes in which outlet. This was possible with the IGenerator approach, but seams to be complicated with the new JvmModelInferrer approach.
Use case example:
Generation of abstract classes is more user friendly, if the standard implementations are also generated but only once. (Output directory: "src", override: false)
Thank you!
Re: Using multiple OutputConfigurations with an JvmModelInferrer [message #929494 is a reply to message #928660] Mon, 01 October 2012 09:56 Go to previous messageGo to next message
Hi Boris,
I'd put an eAdapter into the inferred type to indicate the output config
and read that one from a subclassed JvmModelGenerator in order to direct
the file into the right directory.
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 30.09.12 14:37, schrieb Boris Brodski:
> Hello,
> Use case example:
> Thank you!
Re: Using multiple OutputConfigurations with an JvmModelInferrer [message #929549 is a reply to message #928660] Mon, 01 October 2012 10:58 Go to previous messageGo to next message
Hello Sebastian,
thank you, I will try it out.
Re: Using multiple OutputConfigurations with an JvmModelInferrer [message #1008183 is a reply to message #929549] Mon, 11 February 2013 05:26 Go to previous message
it worked! Thank you very much for help.
And here is the new screen cast: http://xtextcasts.org/episodes/16-output-configurations-with-xbase Smile
Boris
Previous Topic:Xtext/Xtend is not resolving binary operations properly
Next Topic:xtend-maven-plugin has no outputs
Current Time: Sat Jul 19 06:56:47 EDT 2025
Powered by FUDForum. Page generated in 0.03487 seconds
