Home » Archived » Hudson » Error while building a grails app(I am getting error FATAL: groovy/lang/Binding when trying to build a grails project)
Error while building a grails app [message #1007757] Thu, 07 February 2013 07:23 Go to next message
So everything worked fine until u updated hudson to 3.0 version.
Grails is updated too to 2.1.1 version.
Any idea what is causing this?
java.lang.NoClassDefFoundError: groovy/lang/Binding
	at com.g2one.hudson.grails.GrailsBuilder.evalTarget(GrailsBuilder.java:208)
	at com.g2one.hudson.grails.GrailsBuilder.perform(GrailsBuilder.java:168)
	at hudson.tasks.BuildStepMonitor$1.perform(BuildStepMonitor.java:34)
	at hudson.model.AbstractBuild$AbstractRunner.perform(AbstractBuild.java:646)
	at hudson.model.Build$RunnerImpl.build(Build.java:181)
	at hudson.model.Build$RunnerImpl.doRun(Build.java:136)
	at hudson.model.AbstractBuild$AbstractRunner.run(AbstractBuild.java:434)
	at hudson.model.Run.run(Run.java:1390)
	at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:40)
	at hudson.model.ResourceController.execute(ResourceController.java:81)
	at hudson.model.Executor.run(Executor.java:137)
Caused by: java.lang.ClassNotFoundException: groovy.lang.Binding
	at org.aspectj.weaver.bcel.ExtensibleURLClassLoader.findClass(ExtensibleURLClassLoader.java:54)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
	... 11 more
Re: Error while building a grails app [message #1007820 is a reply to message #1007757] Thu, 07 February 2013 11:15 Go to previous messageGo to next message
Groovy is removed from Hudson 3.0.0 due to IP provenance issue. Appears we failed to update the Grails plugin to include Groovy, so that it won't fail. I will fix this and release a new version shortly.
Re: Error while building a grails app [message #1007825 is a reply to message #1007820] Thu, 07 February 2013 11:25 Go to previous messageGo to next message
Would you let us know here or do you have a url i should monitor?
Re: Error while building a grails app [message #1007895 is a reply to message #1007825] Thu, 07 February 2013 20:14 Go to previous messageGo to next message
Once I release a new version, I will announce the release here, then you can update from Hudson update center
Re: Error while building a grails app [message #1008105 is a reply to message #1007895] Fri, 08 February 2013 21:02 Go to previous message
Hi nem,
I released grails version 1.7-h-1 and uploaded it to plugin center. You can updated it from your Hudson's update center. I tested the plugin and it seems to work fine in Hudson 3.0.0. Here is a sample output
[workspace] $ /Users/wjprakash/grails/2.1.1/bin/grails test-app --non-interactive --plain-output
|Loading Grails 2.1.1
|Configuring classpath
|Environment set to test
|Installing zip webxml-1.4.1.zip...
|Installed plugin webxml-1.4.1
|Resolving plugin JAR dependencies
|Compiling 2 source files
|Compiling 40 source files
|Compiling 21 source files
|Compiling 1 source files
|Running 6 unit tests...
|Running 6 unit tests... 1 of 6
|Running 6 unit tests... 2 of 6
|Running 6 unit tests... 3 of 6
|Running 6 unit tests... 4 of 6
|Running 6 unit tests... 5 of 6
|Running 6 unit tests... 6 of 6
|Completed 6 unit tests, 0 failed in 6382ms
|Packaging Grails application
|Tests PASSED - view reports in /Users/wjprakash/Hudson/Hudson3-plugins/grails-plugin/work/jobs/grails-test/workspace/target/test-reports
Finished: SUCCESS
Previous Topic:Error installing using yum on CentOS
Next Topic:Can not make Clone Workspace SCM Plugin version 0.5 work on Hudson
Current Time: Sun Jul 20 08:03:56 EDT 2025
Powered by FUDForum. Page generated in 0.04070 seconds
