Home » Archived » BIRT » BIRT Bubble Chart not exporting to pdf
BIRT Bubble Chart not exporting to pdf [message #1007211] Mon, 04 February 2013 22:11 Go to next message
I have searched and cannot find anything vaguely similar ...
I am using the following:
Eclipse 3.4.2
BIRT Chart plugins are version 2.3.2
Adobe is 11.0.0.1 and there are no updates apparently.
I have 2 cross tabs and a bubble chart in my report. I run it in Web Viewer and it displays fine. However, when I export the report to PDF, the bubble chart is missing - everything above and below it is there, but a blank box where the bubble chart should be.
If you have a bubble chart that you managed to export to PDF fine, I'd love to hear from you.
Thanks.
Re: BIRT Bubble Chart not exporting to pdf [message #1007343 is a reply to message #1007211] Tue, 05 February 2013 10:19 Go to previous messageGo to next message
I created a simple bubble chart report in BIRT 2.3.2 and had no issues with it exporting to PDF. Can you create a report with the sample database that has this issue for you and attach it?
If you change the chart to another type, is it exporting for you?
Re: BIRT Bubble Chart not exporting to pdf [message #1007643 is a reply to message #1007343] Wed, 06 February 2013 15:59 Go to previous messageGo to next message
Hi Michael and thank you for your reply.
I discovered that if I use the option: Run > View Report > as PDF ..... it works fine.
I was using this option: Run > View Report > In Web Viewer ..... then using the "Export Report" button and choosing "PDF" as the format. That did not work.
Before I run off and create something from the sample database (a bit pressed for time at the moment), which option were you using?
Thanks again for replying.
Kind regards,
Debbie
Re: BIRT Bubble Chart not exporting to pdf [message #1007646 is a reply to message #1007643] Wed, 06 February 2013 16:15 Go to previous message
I also exported from the web viewer.
Previous Topic:Hide rows description in crosstab
Next Topic:Where can I find the source code for birt-tests-suite-4_2_1?
Current Time: Sun Jul 20 09:58:54 EDT 2025
Powered by FUDForum. Page generated in 0.47157 seconds
