Home » Eclipse Projects » Eclipse Platform » p2 repository problems
p2 repository problems [message #1007070] Mon, 04 February 2013 05:45 Go to next message
I'm using Helios 3.6.2 and I have a plugin built with maven (no errors) that 2 weeks ago installed fine, now I see this when I try to install:
No repository found containing: osgi.bundle,org.eclipse.net4j.jms.api,3.0.0.v20110215-1551
I'm no expert on the build process but I cannot find a direct reference to net4j in any of our pom files.
I also notice that other plugins from the Helios update site have similar problems, such as EMF 2.6.1.
My plugin also fails to install into 3.7 Indigo with the same error.
I have deleted my maven repository, rebuilt again, and tried to install into a fresh 3.6.2 and always get the same issue.
Any help would be very welcome.
Mark.
Re: p2 repository problems [message #1007753 is a reply to message #1007070] Thu, 07 February 2013 07:17 Go to previous message
I found my problem was the version of Java in my path and JAVA_HOME setting. I downloaded the latest java 6 to work with Eclipse 3.6.2 and now all is well.
Ta,
Mark.
Previous Topic:eclipse heap out of memory while pasting
Next Topic:Java Build Path Libraries disappear
Current Time: Sun Jul 20 04:26:46 EDT 2025
Powered by FUDForum. Page generated in 0.03223 seconds
