Home » Eclipse Projects » EGit / JGit » egit upgrade fails due to conflicting dependency
egit upgrade fails due to conflicting dependency [message #1001567] Wed, 16 January 2013 19:30 Go to next message
On Juno, I attempted to upgrage egit to 2.2, but this failed. Here's the error message
Your original request has been modified.
"Eclipse EGit" is already installed, so an update will be performed instead.
"Eclipse JGit" is already installed, so an update will be performed instead.
Cannot complete the install because of a conflicting dependency.
Software being installed: Eclipse EGit 2.2.0.201212191850-r (org.eclipse.egit.feature.group 2.2.0.201212191850-r)
Software currently installed: Eclipse EGit Mylyn GitHub Feature 2.1.0.201209190230-r (org.eclipse.mylyn.github.feature.feature.group 2.1.0.201209190230-r)
Only one of the following can be installed at once:
Git Team Provider UI 2.2.0.201212191850-r (org.eclipse.egit.ui 2.2.0.201212191850-r)
Git Team Provider UI 2.1.0.201209190230-r (org.eclipse.egit.ui 2.1.0.201209190230-r)
Cannot satisfy dependency:
From: Eclipse EGit 2.2.0.201212191850-r (org.eclipse.egit.feature.group 2.2.0.201212191850-r)
To: org.eclipse.egit.ui
From: Eclipse EGit Mylyn GitHub Feature 2.1.0.201209190230-r (org.eclipse.mylyn.github.feature.feature.group 2.1.0.201209190230-r)
To: org.eclipse.mylyn.github.ui [2.1.0.201209190230-r]
From: Mylyn GitHub Connector UI 2.1.0.201209190230-r (org.eclipse.mylyn.github.ui 2.1.0.201209190230-r)
To: package org.eclipse.egit.ui [2.1.0,2.2.0)
Re: egit upgrade fails due to conflicting dependency [message #1004254 is a reply to message #1001567] Tue, 22 January 2013 16:44 Go to previous messageGo to next message
You've also installed the GitHub connector 2.1 which wants org.eclipse.egit.ui 2.1. So either update both
EGit and the GitHub connector to 2.2 at the same time or uninstall the Github connector, update EGit and
then reinstall the Github connector.
Re: egit upgrade fails due to conflicting dependency [message #1006327 is a reply to message #1004254] Wed, 30 January 2013 15:46 Go to previous messageGo to next message
I have no idea how to upgrade both at the same time. So I uninstalled both of them (as per the insructions at http://wiki.eclipse.org/FAQ_How_do_I_remove_a_plug-in%3F), then reinstalled them via the eclipse marketplace.
Re: egit upgrade fails due to conflicting dependency [message #1008359 is a reply to message #1001567] Tue, 12 February 2013 02:50 Go to previous messageGo to next message
Is there a way to upgrade Eclipse for RCP and RAP Developers Version: Juno Service Release 1 to EGit 2.2?
Neither Install New Software nor Uninstalling does work for me.
Installing EGit 2.2 fails exactly the same way as Loren described.
When trying to uninstall EGit/JGit 2.1 via "Help->About Eclipse" I find the Uninstall... button disabled.
Re: egit upgrade fails due to conflicting dependency [message #1015488 is a reply to message #1001567] Thu, 28 February 2013 12:44 Go to previous message
Same problem here.
Solved adding new "update site"
http://download.eclipse.org/egit/github/updates-2.3
teh just use "check for updates" without reinstalling anything. It worked for me.
Hope it helps
Previous Topic:Older releases of EGit.
Next Topic:How to list files affected in a commit ?[SOLVED]
Current Time: Sat Jul 19 08:31:51 EDT 2025
Powered by FUDForum. Page generated in 0.07572 seconds
