Home » Modeling » Compare » Using EMF Compare to Compare Other Files
Using EMF Compare to Compare Other Files [message #671160] Mon, 16 May 2011 19:22 Go to next message
Greetings Everybody,
I was wondering if we can use EMF Compare to compare files other than .ecore .uml.
I have some models in an XML format and was wondering if there was a way of providing EMF Compare with the meta models and use it to compare those new formats.
Thanks in advance,
Frank
Re: Using EMF Compare to Compare Other Files [message #696222 is a reply to message #671160] Wed, 13 July 2011 10:23 Go to previous messageGo to next message
Yes you definitely can, EMF Compare is able to compare any kind of EMF model, ecore and uml only being some of them.
See this blog post about comparing pom.xml for instance :
http://model-driven-blogging.blogspot.com/2011/06/comparing-pomxml-files-while-waiting.html
It also works in comparing xText based DSL for instance.
To enable EMF compare on another file extension, have a look on the FAQ :
http://wiki.eclipse.org/EMF_Compare/FAQ#Which_files_should_be_compared_via_EMF_Compare_.3F
? [message #1006205 is a reply to message #696222] Wed, 30 January 2013 07:57 Go to previous message
No Message Body
[Updated on: Wed, 30 January 2013 08:49] by Moderator
Previous Topic:EMF Compare bugzilla change
Next Topic:compare two xml models?
Current Time: Sat Jul 19 12:26:36 EDT 2025
Powered by FUDForum. Page generated in 0.02955 seconds
