simpleDateFormat [message #100426] |
Wed, 06 June 2007 09:52  |
Hello !
I have a problem when I run a JUnit test which was generated by TPTP after
HTTP recording.
I have a lot of errors like:
java.lang.NoClassDefFoundError: com/ibm/icu/text/SimpleDateFormat
java.exception:
java.lang.StringIndexOutOfBoundsException: String index out of range: -6
Have you a solution ?
Pierre
Re: simpleDateFormat [message #100495 is a reply to message #100426] |
Wed, 06 June 2007 13:32   |
Hi Pierre,
If I had to guess, I would say that you are running TPTP 4.3 (perhaps on
top of Eclipse 3.2.1, which is an unsupported configuration), and are
encountering the following defect:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=173136
Please try the current TPTP release: 4.3.1
[http://www.eclipse.org/tptp/home/downloads/?ver=4.3.1], which contains
a fix for this issue. The issue is also fixed in the development
version -- 4.4.
If this does not correct the problem for you, please respond with the
version of TPTP and Eclipse that you are using, and also let us know if
you are using the Integrated Agent Controller, or the full AC. [If you
don't know the answer to that question, you're likely using the
Integrated Agent Controller.]
--Joe
Pierre wrote:
> Hello !
> after HTTP recording.
> java.exception:
> Regards
> Pierre
FUDForum. Page generated in 0.04030 seconds
