Home » Eclipse Projects » Rich Client Platform (RCP) » Hiding and restoring a view in RCP
Hiding and restoring a view in RCP [message #1005350] Thu, 24 January 2013 20:36 Go to next message
I have 4 views in my perspective. I need to hide a view and restore it on.
But what i inferred is eclipse is closing the view on the call of hideView() and showView is creating a new view. But i need to just hide and show the view as it works for "View - > Console / View -> error log " in eclipse.
My sample code
IWorkbenchPage activePage = PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage();
String viewIdToToggle = HBinningView.ID;
IViewReference viewToToggle = activePage.findViewReference(viewIdToToggle);
Shell shell = PlatformUI.getWorkbench().getActiveWorkbenchWindow()
.getShell();
if (!isChecked()) {
activePage.hideView(viewToToggle);
} else {
try {
activePage.showView(viewIdToToggle);
} catch (PartInitException e) {
e.printStackTrace();
Re: Hiding and restoring a view in RCP [message #1005457 is a reply to message #1005350] Fri, 25 January 2013 09:18 Go to previous messageGo to next message
Hmmm... Sounds fishy. I just tested your code by placing a break point at the beginning of the createPartControl(Composite parent) method of the View, and it's only called once when it's initially created.
From that point forward createPartControl(Composite parent) is never called again; indicating it's not re-creating the view per activePage.showView(viewIdToToggle) call.
I put another break point in the dispose() method of the View, and sure enough, it's only called once when the platform is shutdown. Again, indicating the view is only disposed once.
Is this a trick question? Or am I misinterpreting the question?
[Updated on: Fri, 25 January 2013 09:20] by Moderator
Re: Hiding and restoring a view in RCP [message #1005641 is a reply to message #1005457] Sun, 27 January 2013 20:15 Go to previous messageGo to next message
I think you haven' called activePage.hideView(viewToToggle); . If just showview() is called, createPartControl() will not be called.
Try calling activePage.hideView(viewToToggle); and then activePage.showView(viewIdToToggle); . Now a new view is getting created for me. You can find that createPartControl() being called again..
Prasanth
Re: Hiding and restoring a view in RCP [message #1005646 is a reply to message #1005641] Sun, 27 January 2013 21:54 Go to previous messageGo to next message
I'm seriously only going to entertain this one more time, so give me a minute to run a quick test.
Re: Hiding and restoring a view in RCP [message #1005647 is a reply to message #1005646] Sun, 27 January 2013 22:05 Go to previous messageGo to next message
Interesting, now it's disposing each time I hide it. Let me dig further.
Re: Hiding and restoring a view in RCP [message #1005650 is a reply to message #1005647] Sun, 27 January 2013 23:02 Go to previous messageGo to next message
Okay, sorry it took so long. For some reason when I tried this the other day it wasn't disposing or re-instantiating the view each time I closed/reopened it. I don't know what I was doing differently than now, but in any case, I think this is what you're looking for:
if (!open) {
	IViewPart view = PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage().findView(TestView.ID);
	PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage().activate(view);
} else {
	IViewPart part = PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage().findView(TestView.ID);
	IWorkbenchPartReference ref = PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage().getReference(part);
	PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage().setPartState(ref, IWorkbenchPage.STATE_MINIMIZED);
open = !open;
Re: Hiding and restoring a view in RCP [message #1005656 is a reply to message #1005650] Mon, 28 January 2013 00:17 Go to previous messageGo to next message
I even tried this one too . But problem in my case is I have two views separated by tabs. [If i click on one tab it shows 1 view and another tab, it shows other view ] Now if you minimize , it minimizes the whole view rather than that particular tab.
Re: Hiding and restoring a view in RCP [message #1005659 is a reply to message #1005656] Mon, 28 January 2013 00:27 Go to previous messageGo to next message
I need something similar to the console view in eclipse. I can close the console window and then select the console from View -> console, and same contents are retained [and note its a tab ]
Re: Hiding and restoring a view in RCP [message #1005666 is a reply to message #1005659] Mon, 28 January 2013 02:27 Go to previous messageGo to next message
Did you tested if console view is not also disposed but it remebers it's
state?
One more thing to remember with this is that: Of course Eclipse will
dispose views when they are hidden. A reason why one is not can be that
you have multiple perspectives open and the view is shown in multiple ones.
Tom
Am 28.01.13 06:27, schrieb Prasanth Jonna Vamsi:
Re: Hiding and restoring a view in RCP [message #1005701 is a reply to message #1005656] Mon, 28 January 2013 05:34 Go to previous message
I see, if I'm understanding this correctly, if you toggle the view when the two views are within the same Folder the entire Folder is being minimized. I didn't have this problem because I put the view that I was minimizing in its own Folder within the perspective, so the view performing the minimizing action doesn't also get minimized.
j
Prasanth Jonna Vamsi wrote on Mon, 28 January 2013 00:17
Previous Topic:Enable/disable command handlers depending on command parameter
Next Topic:Cheatsheet: async action problem
Current Time: Sun Jul 20 08:10:13 EDT 2025
Powered by FUDForum. Page generated in 0.36954 seconds
