Home » Modeling » TMF (Xtext) » [SOLVED] The feature 'eClassifier' of '...EGenericTypeImpl...' contains an unresolved proxy
icon5.gif  [SOLVED] The feature 'eClassifier' of '...EGenericTypeImpl...' contains an unresolved proxy [message #984344] Wed, 14 November 2012 11:11 Go to next message
In one of my DSL projects, I suddenly get these errors in my I18nDsl.ecore model:
The feature 'eClassifier' of 'org.eclipse.emf.ecore.impl.EGenericTypeImpl@4c645550{platform:/resource/project.i18n_dsl/target/classes/project/i18n_dsl/I18nDsl.ecore#//Import/typeRef/@eGenericType}' contains an unresolved proxy
'org.eclipse.emf.ecore.impl.EClassImpl@fa9ccf9{platform:/resource/project.i18n_dsl/org.eclipse.xtext.common.types/model/JavaVMTypes.ecore#//JvmType}'	I18nDsl.ecore
/project/target/classes/project/i18n_dsl
/project/target/classes/project/i18n_dsl/I18nDsl.ecore
Xtext Check (fast)
What might be causing this?
A. Digulla
[Updated on: Tue, 19 November 2013 07:44] by Moderator
Re: The feature 'eClassifier' of '...EGenericTypeImpl...' contains an unresolved proxy [message #1005352 is a reply to message #984344] Thu, 24 January 2013 21:23 Go to previous messageGo to next message
I have the exact same problem. Eclipse suddenly started showing these build error messages for the xtext generated .ecore file (which was generated in from my .xtext grammar file).
When I run my DSL application there actually no problems with the cross references.
Did you ever figure out how to fix this?
Martin
Re: The feature 'eClassifier' of '...EGenericTypeImpl...' contains an unresolved proxy [message #1005540 is a reply to message #1005352] Sat, 26 January 2013 06:47 Go to previous messageGo to next message
No, I still wait for an answer to my question.
Re: The feature 'eClassifier' of '...EGenericTypeImpl...' contains an unresolved proxy [message #1196481 is a reply to message #984344] Tue, 19 November 2013 07:43 Go to previous message
I have now figured it out:
The error is
The feature 'eClassifier' of 'org.eclipse.emf.ecore.impl.EGenericTypeImpl@XXX{platform:/resource/com.pany.eclipse.plugin/target/classes/.../Foo.ecore#//...}' contains an unresolved proxy 'org.eclipse.emf.ecore.impl.EClassImpl@XXX{platform:/resource/com.pany.eclipse.plugin/org.eclipse.xtext.common.types/model/JavaVMTypes.ecore#//JvmTypeReference}'
The important part was "target/classes" (had to spot, it's in the first resource URL).
This means that sometimes, the Xtext builder will see the files created by a command line Maven build (for example when you split the Maven and Eclipse target folders).
To solution is to tell Eclipse to ignore those folders.
Select the folder "target" -> Context Menu -> Properties -> Resource -> Resource Filters (it's a child of "Resource").
Click "Add..." to create a new filter.
Select "Exclude all", "Folders", "Name", "matches", type "classes" into the text field, "Case sensitive".
index.php/fa/16771/0/
If you have a test-classes folder, do the same for it.
Previous Topic:Outline View In Xtext
Next Topic:Using DSL outside Eclipse
Current Time: Sat Jul 19 15:14:55 EDT 2025
Powered by FUDForum. Page generated in 0.04586 seconds
