Home » Archived » Jubula » Each Test Suite requires an AUT setting for Execution. New(Cannot open object mapping editor for test suit)
Each Test Suite requires an AUT setting for Execution. New [message #902385] Fri, 17 August 2012 08:08 Go to next message
hi,
im new to jubula and have following problem:
i tried to walk through the html tutorial in jubula. (aut run with firefox 13.0.1)
AUT-Agent is running and connected, testsuit with a testcase was created.
i can start the aut agend and the test, but when i open the object mapping editor,
it does not adopt the components i've set. Sad
the mysterious thing is, that i can add components directly from the aut. but not automatical from the test.
on the test suit there is an error: "Each Test Suite requires an AUT setting for Execution". but aut setting is set and i can start the aut by using jubula.
if i disable teststyle for my project the error disappears, but my problem with the object mapping editor does not.
did someone else had this problem or has anyone an idea to solve it?
thank you very much!
greetings max
Re: Each Test Suite requires an AUT setting for Execution. New [message #903987 is a reply to message #902385] Mon, 27 August 2012 10:00 Go to previous messageGo to next message
In the properties view for a test suite, you can select the AUT from a combo-box as described here.
HTH,
Alex
Re: Each Test Suite requires an AUT setting for Execution. New [message #1003899 is a reply to message #903987] Tue, 22 January 2013 02:52 Go to previous messageGo to next message
Hi Alex,
I met this problem too. And I saw that "Select the AUT for this Test Suite . "but i don't know how? Can I Select an existed AUT for my Test Suit (If it works ,what the operation steps?), Or I have to create a new one?
Thanks a lot,
Posia
[Updated on: Tue, 22 January 2013 03:03] by Moderator
Re: Each Test Suite requires an AUT setting for Execution. New [message #1003935 is a reply to message #902385] Tue, 22 January 2013 04:24 Go to previous message
In my problem,when I want to create a new testsuit to the Project(which reference only one AUT),I should click on the project name and then do the operation to create a new testsuit.and it solved.But if the project reference more than one AUT, this method doesn't work any more.
Hope that helps,
posia
[Updated on: Tue, 22 January 2013 06:10] by Moderator
Previous Topic:AUT Agent on AIX ,couldn't start AUT with Excutable File name such as .sh file
Next Topic:Central data set as a parameters for standard Actions
Current Time: Sat Jul 19 23:14:00 EDT 2025
Powered by FUDForum. Page generated in 0.04010 seconds
