Invoking RCP plugin [message #1001541] |
Wed, 16 January 2013 17:33  |
I'm afraid this might be a common question, which already have been answered on the forum. However, after spending quite much time trying to find the answer, please help.
I have created 2 RCP plugins, both singletons - I want them to run as separate processes.
Question. How do I start plugin #2 from plugin #1, in the java code. Can someone please advice me where to find this information.
Grateful for help.
Cheers
Kabo
Re: Invoking RCP plugin [message #1002349 is a reply to message #1002333] |
Fri, 18 January 2013 07:42   |
Yes. Thanks.
I've created
plugin_1
feature_1, using plugin_1
and product_1, using feature_1, starting a window application defined in plugin_1.
Then I've created
plugin_2
feature_2, using plugin_2
and product_2, using feature_2, starting a window application defined in plugin_2.
Both of those products runs fine as standalone programs.
Now, when I press a button in plugin_1, I want to make some java software call to start plugin_2 as a standalone software (the two plugins will do some inter-process communication testing). Is this possible or is there even an easy way to do this?
[Updated on: Fri, 18 January 2013 08:41] by Moderator
FUDForum. Page generated in 0.29040 seconds
