Sequence Diagrams [message #999073] |
Fri, 11 January 2013 04:25  |
Consider this simple example:
I have a model with a class ClassA containing two instances of two different classes (say bObj:ClassB and cObj:ClassC).
ClassA provides an Operation (i.e. classAOperation(int param)) related to a Behavior specified by means of a SequenceDiagram.
Now the behavior consists of invoking an Operation of bObj:ClassB (i.e. classBOperation(int param)) and an Operation of cObj:ClassC (i.e. classCOperation(int param)).
I am wondering how to model, this very simple behavior, via SD.
The question is basically related to LifeLine.
According to the OMG spec. a Lifeline can only represent (Represents attribute) a ConnectableElement, which in my case are two and correspond to the ClassA Properties realizing the composition to a ClassB and a ClassC instance (bObj and cObj). The Problem is I also need to have a reference to the container of these connectable elements, that is to say the ClassA instance which is actually performing such emergent behavior. It is that instance which sends messages (related to the operation call) o to the bObj:ClassB and cObj:ClassC lifelines.
Also as this behavior corresponds to the ClassA:classAOperation(int param) invocation I also need to represents by means of a formal gate the classAOperation(int param) message. But again, as I can't mode the container Lifeline I can't see to which attach the classAOperation(int param) message end.
Re: Sequence Diagrams [message #999147 is a reply to message #999073] |
Fri, 11 January 2013 07:52   |
Hi, Andrea,
A Collaboration is a structured classifier in which you can create any
number of parts (owned attributes) to define ad hoc collaboration roles
for your sequence diagram. The interaction "behind" your diagram would
be an owned behaviour of the collaboration.
Classifiers can refer to the Collaboration via CollaborationUses as
part of their specification.
HTH,
Christian
> different classes (say bObj:ClassB and cObj:ClassC). ClassA provides an
> I am wondering how to model, this very simple behavior, via SD. The
> param) message end.
Re: Sequence Diagrams [message #999568 is a reply to message #999496] |
Sat, 12 January 2013 08:46   |
Hi, Andrea,
Communication diagrams are an alternative to sequence diagrams to
visualize an Interaction. My point was that you can create the
Interaction as an owned behaviour of a Collaboration instead of your
ClassA.
In the collaboration, create roles (owned attributes) of type ClassB,
ClassC, and ClassA. Then create an Interaction as an owned behaviour
of the collaboration and create lifelines for these roles.
Then create a CollaborationUse in ClassA that references the
collaboration and maps elements of ClassA to the collaboration's roles
using Dependencies referenced as the collaboration-use's "role
bindings".
HTH,
Christian
On 2013-01-12 08:49:31 +0000, Andrea Sindico said:
> Hi Christian,
> I guess you mean Communication Diagram. Actually the same thing holds
> for Communication diagrams as well as there is no way (at least it
> seems to me) to make a Lifeline representing the container instance,
> which is the one actually sending messages to its parts. What am I
> doing wrong?
Re: Sequence Diagrams [message #999672 is a reply to message #999659] |
Sat, 12 January 2013 15:50   |
Hi, Andrea,
Yes, Dependency is the most appropriate type for a role binding. The
other metaclasses are subtypes of Dependency that have specific
semantics associated with them.
Yes, your role bindings as you describe them are correct.
A dependency can have any named element as a client, so I would think
that you could just bind the ClassA itself to the corresponding role in
the collaboration. Technically, this would be incorrect (there's a
well-formedness rule that requires the elements on both ends of the
role bindings to be ConnectableElements), but I don't know how else it
could be done. If your ClassB and ClassC ever need to send messages
back to ClassA (instead of just receiving messages), then they would
need either a variable of a property of type ClassA. These are both
connectable elements.
HTH,
Christian
On 2013-01-12 20:04:45 +0000, Andrea Sindico said:
> I managed to do what you suggested. I created two Role Bindings in
> CollaborationUse with dependencies. I used the Client attributes to
> refer to the ClassA.bObj and ClassA.cObj attributes while the Supplier
> attributes to refer to the related properties of the CollaborationUse.
> Is it correct?
> Also, as I do not have an attribute for the ClassA instance I can't see
> how to bind the ClassA instance with the related property of the
> CollaborationUse.
> I noticed the editor suggested me many alternatives to specify the binding:
> - Abstraction
> - ComponentRealization
> - Dependency
> - Deployment
> - InterfaceRealization
> - Manifestation
> - Realization
> - Substitution
> - Usage
> Should I always use dependency for this purpose or there might be cases
> in which another kind of binding is more appropriate?
> thank you for your kind help
Re: Sequence Diagrams [message #1005283 is a reply to message #999073] |
Thu, 24 January 2013 14:25   |
Hi you two,
maybe this is not relevant anymore, but technically the simplest solution
would have been to:
- create the interaction as owned behavior of ClassA
- create another lifeline for ClassA in addition to those for the properties
- label the additional lifeline with self!
This is at least the UML-compliant way. See the notation rules for lifelines
in UML 2.5 beta 1:
<lifelineident> ::= ([<connectable-element-name>[‘[‘ <selector> ‘]’]] [:
<class_name>] [decomposition]) | ‘self’
<selector> ::= <expression>
<decomposition> ::= ‘ref’ <interactionident> [‘strict’]
And the corresponding description:
If the name is the keyword self, then the Lifeline represents the object of
the classifier that encloses the Interaction that owns the
Lifeline. Ports of the encloser may be shown separately even when self is
included.
Anyway, I suspect that Papyrus is able to deal with such (self) lifelines
properly.
HTH,
Marc-Florian
"Andrea Sindico" schrieb im Newsbeitrag
news:kcolpj$2ki$1@xxxxxxxxe.org...
end.
Re: Sequence Diagrams [message #1005294 is a reply to message #1005283] |
Thu, 24 January 2013 14:47   |
Hi, Marc-Florian,
Thanks! That is good information to have. However, this does mean
that the lifeline ends up without a 'represents' association to some
connectable element. That is an unfortunate asymmetry, but is probably
not too difficult for a tool that analyzes the interaction model to
interpret.
cW
On 2013-01-24 19:25:18 +0000, Florian Wendland said:
> Hi you two,
> solution would have been to:
> lifelines in UML 2.5 beta 1:
> <lifelineident> ::= ([<connectable-element-name>['[' <selector> ']']]
> [: <class_name>] [decomposition]) | 'self'
> <decomposition> ::= 'ref' <interactionident> ['strict']
> object of the classifier that encloses the Interaction that owns the
> is included.
> lifelines properly.
> HTH,
> Marc-Florian
-------- 8< --------
Re: Sequence Diagrams [message #1005305 is a reply to message #1005302] |
Thu, 24 January 2013 15:24  |
In the LifeLines' constraints at page 660 I would add
inv: self.name='self' implies self.represents.isEmpty()
inv: self.name<>'self' implies self.represents.notEmpty()
What do you think?
FUDForum. Page generated in 0.05331 seconds
