Home » Newcomers » Newcomers » Spaces for tabs (in Indigo)?
Spaces for tabs (in Indigo)? [message #999752] Sat, 12 January 2013 21:56 Go to next message
(Indigo 64-bit, Ubuntu Lucid.)
I've checked General -> Editors -> Text Editors -> Insert spaces for
tabs and then find the Java editor leaving tabs in the file anyway. I've
verified after saving (and closing) Java files that the tabs do persist.
Even if I take the tabs out by hand, more are left in as I press the tab
key afterward.
Am I missing something?
Much thanks.
Re: Spaces for tabs (in Indigo)? [message #999789 is a reply to message #999752] Sun, 13 January 2013 00:53 Go to previous messageGo to next message
Russell,
The Java -> Code Style -> Formatter's active profile determines this, in
particular, the Indention tab's Tab policy setting.
> I've verified after saving (and closing) Java files that the tabs do
> persist. Even if I take the tabs out by hand, more are left in as I
> press the tab key afterward.
> Much thanks.
Re: Spaces for tabs (in Indigo)? [message #999791 is a reply to message #999752] Sun, 13 January 2013 00:53 Go to previous messageGo to next message
Russell,
> Much thanks.
Re: Spaces for tabs (in Indigo)? [message #999793 is a reply to message #999752] Sun, 13 January 2013 00:53 Go to previous messageGo to next message
Russell,
> Much thanks.
Re: Spaces for tabs (in Indigo)? [message #999796 is a reply to message #999752] Sun, 13 January 2013 00:53 Go to previous messageGo to next message
Russell,
> Much thanks.
Re: Spaces for tabs (in Indigo)? [message #999799 is a reply to message #999752] Sun, 13 January 2013 00:53 Go to previous messageGo to next message
Russell,
> Much thanks.
Re: Spaces for tabs (in Indigo)? [message #999802 is a reply to message #999752] Sun, 13 January 2013 00:53 Go to previous messageGo to next message
Russell,
> Much thanks.
Re: Spaces for tabs (in Indigo)? [message #999806 is a reply to message #999752] Sun, 13 January 2013 00:53 Go to previous messageGo to next message
Russell,
> Much thanks.
Re: Spaces for tabs (in Indigo)? [message #999810 is a reply to message #999752] Sun, 13 January 2013 00:53 Go to previous messageGo to next message
Russell,
> Much thanks.
Re: Spaces for tabs (in Indigo)? [message #999814 is a reply to message #999752] Sun, 13 January 2013 00:53 Go to previous messageGo to next message
Russell,
> Much thanks.
Re: Spaces for tabs (in Indigo)? [message #999818 is a reply to message #999752] Sun, 13 January 2013 00:53 Go to previous messageGo to next message
Russell,
> Much thanks.
Re: Spaces for tabs (in Indigo)? [message #999822 is a reply to message #999752] Sun, 13 January 2013 00:53 Go to previous messageGo to next message
Russell,
> Much thanks.
Re: Spaces for tabs (in Indigo)? [message #999823 is a reply to message #999752] Sun, 13 January 2013 01:46 Go to previous messageGo to next message
Did you check for a similar setting specific to the Java Editor?
Re: Spaces for tabs (in Indigo)? [message #999827 is a reply to message #999752] Sun, 13 January 2013 00:53 Go to previous messageGo to next message
Russell,
> Much thanks.
Re: Spaces for tabs (in Indigo)? [message #999831 is a reply to message #999752] Sun, 13 January 2013 00:53 Go to previous messageGo to next message
Russell,
> Much thanks.
Re: Spaces for tabs (in Indigo)? [message #999832 is a reply to message #999752] Sun, 13 January 2013 01:46 Go to previous messageGo to next message
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
Re: Spaces for tabs (in Indigo)? [message #999836 is a reply to message #999752] Sun, 13 January 2013 00:53 Go to previous messageGo to next message
Russell,
> Much thanks.
Re: Spaces for tabs (in Indigo)? [message #999837 is a reply to message #999752] Sun, 13 January 2013 01:46 Go to previous messageGo to next message
Nitin Dahyabhai
IBM Rational
Re: Spaces for tabs (in Indigo)? [message #999841 is a reply to message #999752] Sun, 13 January 2013 00:53 Go to previous messageGo to next message
Russell,
> Much thanks.
Re: Spaces for tabs (in Indigo)? [message #999842 is a reply to message #999752] Sun, 13 January 2013 01:46 Go to previous messageGo to next message
Nitin Dahyabhai
IBM Rational
Re: Spaces for tabs (in Indigo)? [message #999846 is a reply to message #999752] Sun, 13 January 2013 01:46 Go to previous messageGo to next message
Nitin Dahyabhai
IBM Rational
Re: Spaces for tabs (in Indigo)? [message #1000057 is a reply to message #999789] Sun, 13 January 2013 17:46 Go to previous messageGo to next message
On 01/12/2013 10:53 PM, Ed Merks wrote:
> Russell,
>> Much thanks.
Thanks, Ed. I used to use tabs, but recently have decided to discontinue
the practice in Java code at least. This is why it's just never come up
in all the years I've used Eclipse.
So, you're right...
Window -> Preferences -> Java -> Code Style -> Formatter -> Edit ->
Indentation -> Tab policy: Spaces only.
This appears to work fine now.
Thanks also to Nitin for replying. It appears that the wiggle above IS
how to configure the Java editor (which otherwise isn't listed
separately, I guess).
Best regards to all,
Russ
Re: Spaces for tabs (in Indigo)? [message #1000372 is a reply to message #1000057] Mon, 14 January 2013 11:04 Go to previous message
it works for me too
Previous Topic:Eclipse broswer applets
Next Topic:Help
Current Time: Sun Jul 20 03:44:53 EDT 2025
Powered by FUDForum. Page generated in 0.10190 seconds
