Home » Eclipse Projects » Mosquitto » Does mosquitto 1.4 support mqtt-sn?
Does mosquitto 1.4 support mqtt-sn? [message #1593476] Fri, 30 January 2015 17:22 Go to next message
HE Guangyu is currently offline HE GuangyuFriend
Mosquitto is a great work. Many thanks.
I will use both mqtt and mqtt-sn at the same time. So I want to know, does mosquitto 1.4 support mqtt-sn?
If not, Do you have a release plan to support mqtt-sn?
Re: Does mosquitto 1.4 support mqtt-sn? [message #1601176 is a reply to message #1593476] Wed, 04 February 2015 19:44 Go to previous messageGo to next message
Roger Light is currently offline Roger LightFriend
Member
I'm afraid that mosquitto doesn't yet support mqtt-sn. The most likely plan is that it will be in the release after 1.4.
Roger
Re: Does mosquitto 1.4 support mqtt-sn? [message #1690438 is a reply to message #1593476] Fri, 27 March 2015 10:24 Go to previous message
Bernd Niehues is currently offline Bernd NiehuesFriend
Hi! When do you plan to release the next version of mosquitto (with mqtt-sn support) ?
Previous Topic:How to import and run the source in eclipse c/c++ ide?
Next Topic:Mosquitto s/w for the solaris version
Current Time: Sat Nov 28 20:46:58 GMT 2020
Powered by FUDForum. Page generated in 0.06274 seconds
