3.2 M4 - org.eclipse.core.commands.common.EventManager cannot be resolved [message #297417] |
Fri, 13 January 2006 12:38 |
Originally posted by: jk.hmail.com
I'm getting this error in an Jface application:
"The type org.eclipse.core.commands.common.EventManager cannot be
resolved. It is indirectly referenced from required .class files"
The code Eclipse is complaining about, is this:
public class ViewRecordLabelProvider extends LabelProvider implements
ITableLabelProvider {
This used to work with 3.2 M3. Am I missing a CLASSPATH entry? Help is
appreciated!
Joachim
Re: 3.2 M4 - org.eclipse.core.commands.common.EventManager cannot be resolved [message #297423 is a reply to message #297421] |
Fri, 13 January 2006 14:28 |
Originally posted by: jk.hotmail.com
Thanks, that did the trick!
Joachim
Paul Webster wrote:
> Joachim wrote:
>> Hello,
>> appreciated!
> In 320M4 there was some reshuffling to fix ListListener. That
> particular class is in org.eclipse.core.commands ... you should be able
> to use that as a JAR (not a plugin) in your JFace app.
> You could open an enhancement request to remove that dependancy, and the
> response would explain why it's there and if there are other options (a
> number of the other dependancies were moved into org.eclipse.equinox.common.
> Later,
> PW
FUDForum. Page generated in 0.02559 seconds
