Ant build-user file [message #292737] |
Tue, 11 October 2005 21:47 |
Originally posted by: thisisnot.mymail.com
I've exported the project's and file and it generated also a
build-user.xml that is references in the build.xml as an entity.
Unfortunately the ant editor doesn't open this build-user.xml. Is this a
known issue about the ant editor that's being worked on?
Re: Ant build-user file [message #292766 is a reply to message #292740] |
Wed, 12 October 2005 11:19 |
If the build file has this:
<!DOCTYPE project [<!ENTITY buildfile SYSTEM "file:./build-user.xml">]>
<!-- WARNING: Eclipse autogenerated file.
Any modifications will be overwritten.
Please edit build-user.xml instead.
<project basedir="." default="build" name="CSAIEJB">
&buildfile;
the build-user.xml file has only the various targets (it's not even a
xml file as it doesn't have the root element). So, when I drag and drop
the file in the Ant view it said <Unable to parse as an Ant buildfile>
(on the better hand the build.xml at least contains all targets both
internal and external from build-user.xml). However the external targets
are not editable with the Ant editor (press second button and it doesn't
list the ant editor in the Open With list).
Darin Swanson wrote:
> Can you explain what you mean by "the ant editor doesn't open this
> build-user.xml"?
> Darins
> "Srgjan Srepfler" <thisisnot@mymail.com> wrote in message
> news:dihbuu$m7q$1@news.eclipse.org...
FUDForum. Page generated in 0.02776 seconds
