Re: Need alternative for org.eclipse.core.resources in eclipse 3.1 [message #291015 is a reply to message #291009] |
Tue, 06 September 2005 12:55 |
Originally posted by: Michael_Valenta.oti.com
Pravin,
This means that you are using code that requires the Resources plugin. You
will need to add the org.eclipse.core.resources to your project dependancies
(or stop using the code that indirectly references IResourceChangeListener).
Michael
"pravinsinh" <pravinsinh_chavda@infosys.com> wrote in message
news:fe7f72875596e6a569ea5b1c11d75ab4$1@www.eclipse.org...
> I have migrated my plugin to eclipse 3.1 from eclipse 3.0.
> Eveerything else works perfectly fine but the import of
> "org.eclipse.core.resources" is not resolved in the my project.
> It gives the following error:
> The type org.eclipse.core.resources.IResourceChangeListener cannot be
> resolved. It is indirectly referenced from required .class files.
> Please advice.
> Pravin.
FUDForum. Page generated in 0.02962 seconds
