Getting ClassNoFoundDef [message #290772] |
Wed, 31 August 2005 19:10 |
Originally posted by: sunitjoshi.netzero.com
I'm trying to run a simple java project in Eclipse3.0 and it was fine till
I tried adding a src and bin folders in the Project->Properties->Source
tab. I added a folder src under my project Ch1 and it added the bin folder
too.
Now when I try to run the Ch1, it says: java.lang.NoClassDefFoundError:
org/sj/Ch1_01
I can see the .java files under ../org/sj/Ch1_01 folder though. All the
files have the statement package org.sj; at the top.
thanks
Sunit
Re: Getting ClassNoFoundDef [message #290773 is a reply to message #290772] |
Wed, 31 August 2005 19:28 |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
The java files need to be under the src folder. Is that where they are?
Are the .class folders in the bin folder?
> till I tried adding a src and bin folders in the
> Project->Properties->Source tab. I added a folder src under my project
> Ch1 and it added the bin folder too.
> org/sj/Ch1_01
> thanks
> Sunit
Rich Kulp
Re: Getting ClassNoFoundDef [message #290774 is a reply to message #290773] |
Wed, 31 August 2005 19:37 |
The bin folder is empty. The src files have the .java files (I'll confirm
that later since its on my home machine)
thanks
Sunit
Re: Getting ClassNoFoundDef [message #290776 is a reply to message #290774] |
Wed, 31 August 2005 19:40 |
Do you have auto build turned on?
> confirm that later since its on my home machine)
> thanks
> Sunit
Rich Kulp
Re: Getting ClassNoFoundDef [message #290782 is a reply to message #290776] |
Thu, 01 September 2005 01:12 |
I removed the src folder under Source folders on build path so that list
is empty. The Default output folder in the same dialog is set to Ch1/org/sj
My directory structure where the .java and .class files are now is
E:\Sunit\JavaFiles\Scripts\Ch1\org\sj\
However when I try to run the main class (with main), I still get this
java.lang.NoClassDefFoundError: org/sj/Ch1_01
Exception in thread "main"
Any help is appreciated.
thanks
Sunit
Re: Getting ClassNoFoundDef [message #290798 is a reply to message #290782] |
Thu, 01 September 2005 13:21 |
Originally posted by: automatic.javalobby.org
You probably didn't set the 'src' to be a Source Folder in the first instance. Then, when you created the launch configuration, it may have cached that value.
I'm assuming that there is a class Ch1_01 and it has a main method? What about right-clicking on the class and selecting 'Run As... Java Application'? Does that give the same result?
If you're running from the command line, you should be in the e:\Sunit\JavaFiles\Scripts\Ch1 directory, and the current directory '.' should be in the classpath. You'd want to have something like:
e:
cd e:\Sunit\JavaFiles\Scripts\Ch1
java -classpath .;%CLASSPATH% org.sj.Ch1_01
Lastly, this error can also be seen when you have a static field that needs to be initialised from another class, so something like:
public class Test {
private static Driver driver = Class.forName("com.ibm.db2.DB2Driver");
can result in a ClassNotFoundException (incorrectly reported as Test). I've also come across this a lot in code like:
public class Test {
private static Log log = LogFactory.getLog(Test.class);
using Log4J, but I doubt that's your problem :-)
Re: Getting ClassNoFoundDef [message #290803 is a reply to message #290782] |
Thu, 01 September 2005 14:28 |
The problems you're having result from a basic misunderstanding of how
Eclipse manages Java code in Projects.
You really need to go through the Help - there is lots of information in
the Getting Started chapter of the Java Development section that will
help you understand how to organize your projects in Eclipse.
HTH,
Eric
FUDForum. Page generated in 0.03688 seconds
