Disabling and enabling icons [message #290736] |
Wed, 31 August 2005 06:15 |
Originally posted by: parsuram.panigrahi.wipro.com
I have created a plugin which listens on a port. I have 3 functionality.
1) Start the application so that it will listen on a port
2) Stop the application, it will close the socket.
3) Give some commands it will execute it on the open socket.
The application is working fine. I don't want anybody to stop the tool
when it is not started or give some command when it is already started.
Simillarly I don't want to start the tool when it is already started.
So I want to enable/disable start/stop/command buttons as required. I
define the name of the action class and the icon name in the plugin.xml.
What do I need to do to enable/disable the icons as required? Where can I
find the schema for plugin.xml?
FUDForum. Page generated in 0.01834 seconds
