Home » Eclipse Projects » Eclipse Platform » How to append some text in an editor at desired position
How to append some text in an editor at desired position [message #290524] Fri, 26 August 2005 05:43 Go to next message
Originally posted by: gkforward.gmail.com
Currently I tried to control an open editor, and I found how to append
some text on it. :
public boolean performFinish() {
try {
IEditorPart editor = JavaPlugin.getActivePage().getActiveEditor();
IFile file = ((FileEditorInput)editor.getEditorInput()).getFile();
String str = previewWizard.getTextData();
file.append(new ByteArrayInputStream(str.getBytes()), true, true, null);
editor.setFocus();
} catch (Exception e) {
e.printStackTrace();
MessageDialog.openError(getShell(), "Error", e.getMessage());
return false;
return true;
But, I can't figure out how to append some text in an active editor at
desired (or, current) cursor position.
Please tell me how can I solve it.
Thank you.
Re: How to append some text in an editor at desired position [message #290591 is a reply to message #290524] Fri, 26 August 2005 15:07 Go to previous messageGo to next message
Originally posted by: sunil_kamath.nohotspammail.com
"Paul E. Kim" <gkforward@gmail.com> wrote in message
news:44ce9b6cf09f85eab4c54664caadec06$1@www.eclipse.org...
> some text on it. :
> try {
> editor.setFocus();
> return false;
> return true;
> Thank you.
Get the editor's IDocument and use that instead of the IFile.
Sunil
Re: How to append some text in an editor at desired position [message #290614 is a reply to message #290591] Sat, 27 August 2005 13:39 Go to previous messageGo to next message
Thank you very much for your answer, Sunil.
So I tried to use IDocument, and it seems to be another interface required
IDocumentProvider, 3.0 API says it is in org.eclipse.ui.texteditor package.
But, I can't find it in [dependencies] tab on [plugin.xml]
when I tried to add it.
It does not appear in [Plug-in Selection] list dialog.
What's wrong with it?
I use Version: 3.0.1 Build id: 200409161125
Re: How to append some text in an editor at desired position [message #290617 is a reply to message #290614] Sat, 27 August 2005 19:13 Go to previous messageGo to next message
news:2b818d2c78b3482e96e6ef788e353b1a$1@www.eclipse.org...
> package.
org.eclipse.ui.workbench.texteditor is the dependency name.
Sunil
Re: How to append some text in an editor at desired position [message #290623 is a reply to message #290617] Sun, 28 August 2005 01:50 Go to previous messageGo to next message
I deeply appreciate your kindness.
Without your help, I couldn't solve my problem.
org.eclipse.ui.workbench.texteditor does work for
org.eclipse.ui.texteditor.
However, still I have doubts.
Why their package name different?
I wonder why it's different. Is there any acceptable reason?
Re: How to append some text in an editor at desired position [message #290643 is a reply to message #290623] Mon, 29 August 2005 10:45 Go to previous messageGo to next message
Yes, we split existing plug-ins into several ones some time ago for RCP.
The package names could not be changed due to API compatibility.
Dani
Re: How to append some text in an editor at desired position [message #290734 is a reply to message #290643] Wed, 31 August 2005 01:26 Go to previous message
Thank you very much, Mr. Megert, and for Mr. Kamath
It was really of great help for me.
I'll end up my question about this topic.
May FORCE be with you...
Previous Topic:Easy Struts plug-in
Next Topic:Export not listing classes for main selection
Current Time: Tue Apr 16 05:10:48 GMT 2024
Powered by FUDForum. Page generated in 0.32114 seconds
