How to use Session Properties for existing projects [message #290508] |
Thu, 25 August 2005 19:11 |
No real name Messages: 3 Registered: July 2009 |
Junior Member |
I want to use session properties in IProject. There is some project specific
data which should be available to other parts of the application (e.g.
project wizard). This is a kind of project manifest file. It can be stored
in session property when the project is. But after creation, when the
workspace is opened and the project is already there, how do you set the
session property again? Currently we are doing in Plugin start. We tag a
project with a project type using a persistent property (during project
creation). Then in plugin start, look for projects of this type, and set the
session property with the project manifest object.
Does not seem the right way. Isn' there a better way of handling this??? No
event seems to be coming when the workspace root is created with open
projects.
regards
Vinay
FUDForum. Page generated in 0.03328 seconds
