Re: Minimum hardware requirements [message #290457 is a reply to message #290431] |
Thu, 25 August 2005 15:27 |
Originally posted by: eclipse3.rizzoweb.com
H.Ceylan wrote:
> Hello,
> I need to find a quick answer for minimum HW requirements for an RCP
> project, for a company that has a range of PCs in hand. I currenly do
> not have access to the existing hardware, therefore "see it for
> yourself" isn't possible.
Did you look for such information on the RCP project pages at
http://www.eclipse.org/rcp/ ?
Did you try posting to the eclipse.platform.rcp group?
Re: Minimum hardware requirements [message #290598 is a reply to message #290431] |
Fri, 26 August 2005 15:49 |
Originally posted by: john.eclipsefaq.org
There is no official minimum, and of course it depends largely on your
particular RCP application's footprint. I have seen simple RCP apps
running on hand-held devices, so the requirements are not high. I
suspect a 400 Mhz machine with 128MB of RAM could handle most simple
applications. If you want to go even smaller, you may be interested in
eRCP which specifically targets embedded and hand-held devices:
http://www.eclipse.org/ercp
H.Ceylan wrote:
> Hello,
> I know it is a bit vauge to ask such a question but since the company
> has PCs ranging from PIIs/32MB RAM to P4 2.4 512MB PCs, I have to draw a
> line somewhere for the hardware upgrade requirements.
> For agents RCP, will run as transaction processing terminals like a bank
> cashier and the software bundle will be as follows:
> Fedora as the OS
> Java 1.5 RCP as the application
> EJB3.0 to communicate with the server
> What do you think? Are there any people that were forced to run their
> RCPs in low end PCs?
> Ceylan
FUDForum. Page generated in 0.03891 seconds
