Re: Intercepting the workbench thread before loading [message #289946 is a reply to message #289878] |
Mon, 15 August 2005 16:36 |
Originally posted by: bokowski.ca.ibm.com
You would have to show the dialog before PlatformUI.createAndRunWorkbench is
called. For this, you need to implement a custom application. Have a look
at IDEApplication from org.eclipse.ui.ide and how it opens a dialog to
prompt you for the workspace location.
Boris.
"Ino" <irichiez@us.ibm.com> wrote in message
news:63be60c7f2bdd19b4c92ad4bbcff3b34$1@www.eclipse.org...
> I'm using a startup plugin to popup a dialog at the starup of the
> workbench launch. Based on the selection of this dialog, I want to load
> (show) the workbench or not. The workbench right now is showing up any how
> so that's one of my problem. How can I stop the UI (workbench) from coming
> up while the dialog (MessageDialog) is running waiting for a selection
> from the user? and how do I gracefully shutdown or close anything that has
> been loaded in the background?
> Thanks...
FUDForum. Page generated in 0.02891 seconds
