Re: Refactor-rename of XML based resources [message #289719 is a reply to message #289648] |
Wed, 10 August 2005 09:28 |
Stefan Junsved Messages: 56 Registered: July 2009 |
Member |
Hi again.
Is there actually no one in this entire news group who hasn't come across
the same problem as I have?
Maybe the title wasn't enough carefully chosen. My ambition is to find out
how to do a rename on a resource, and using the built in IDE functionality
for that as much as possible. Isn't it possible to provide the
refactor->rename with extensive functionality for a certain type of
resource, and when exactly that type of resource is to be renamed, the
provided functionality is executed.
I mean, in the editor case, you just create a plugin with desired editor
type, and in the extension point for the editor you say what file extension
should trig this editor. It's extremely simple and genoius. Couldn't this be
the for all refactoring functionality in the IDE?
/Stefan
"Stefan Junsved" <stefan.junsved@comactivity.net> wrote in message
news:ddagvb$e5$1@news.eclipse.org...
> Hi all.
> I have several resources in my workbench described in xml but edited with
> different GEF editors. I would like to hook into the Eclipse Refactor ->
> Rename functionality when changing the name of an xml resource.
> I have read quiet a lot about this, but it seems as if most issues take
> care of how to rename Java packages, classes, methods, and fields etc,
> etc. I have not found anything about a more generic functionality on how
> to rename any resource not being a Java resource.
> I'd very much appreciate some help with this.
> /Stefan Junsved
Re: Refactor-rename of XML based resources [message #289817 is a reply to message #289719] |
Thu, 11 August 2005 08:06 |
Member |
------=_NextPart_000_000C_01C59E5C.5EAD9060
Content-Type: text/plain;
charset="iso-8859-1"
Before I wrote this issue, I tampered with the =
org.eclipse.ltk.core.refactoring.renameParticipants extension point, but =
I didn't get it to work.
The plugin.xml sub part looks like this:
<extension
point=3D"org.eclipse.ltk.core.refactoring.renameParticipants ">
<renameParticipant
id=3D"myid"
name=3D"myname"=20
class=3D"net.mycompany.eclipse.tools.core.refactoring.MyClass ">
<enablement>
<with variable=3D"affectedNatures">
<iterate operator=3D"or">
<equals value=3D"org.eclipse.jdt.core.javanature"/>
</iterate>
</with>
<with variable=3D"element">
<instanceof value=3D"org.eclipse.core.resources.IResource"/>
</with>
</enablement>
</renameParticipant>
</extension>
MyClass extends the =
org.eclipse.ltk.core.refactoring.participants.RenameParticip ant class. =
Nothing is trigged though in MyClass when a rename is executed. Is there =
anything more I have to do?
I'll start a new thread on this part of the issue.
/Stefan
=20
"Stefan Junsved" <stefan.junsved@comactivity.net> wrote in message =
news:ddchc0$3a9$1@news.eclipse.org...
> Hi again.
>=20
> Is there actually no one in this entire news group who hasn't come =
across=20
> Maybe the title wasn't enough carefully chosen. My ambition is to find =
out=20
> how to do a rename on a resource, and using the built in IDE =
functionality=20
> for that as much as possible. Isn't it possible to provide the=20
> refactor->rename with extensive functionality for a certain type of=20
> resource, and when exactly that type of resource is to be renamed, the =
>=20
> I mean, in the editor case, you just create a plugin with desired =
editor=20
> type, and in the extension point for the editor you say what file =
extension=20
> should trig this editor. It's extremely simple and genoius. Couldn't =
this be=20
>=20
> /Stefan
>=20
> "Stefan Junsved" <stefan.junsved@comactivity.net> wrote in message=20
>> Hi all.
>> I have several resources in my workbench described in xml but edited =
with=20
>> different GEF editors. I would like to hook into the Eclipse Refactor =
->=20
>> I have read quiet a lot about this, but it seems as if most issues =
take=20
>> care of how to rename Java packages, classes, methods, and fields =
etc,=20
>> etc. I have not found anything about a more generic functionality on =
how=20
>> /Stefan Junsved
>>=20
>=20
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2900.2668" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2>Before I wrote this issue, I tampered =
with the=20
</FONT><FONT face=3DArial=20
size=3D2>org.eclipse.ltk.core.refactoring.renameParticipants extension =
point, but=20
I didn't get it to work.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>The plugin.xml sub part looks like=20
this:</FONT></DIV>
<DIV><FONT face=3DArial=20
size=3D2><extension<BR>  =
;=20
point=3D"org.eclipse.ltk.core.refactoring.renameParticipants "><BR>&nbs=
p; <renameParticipant<BR> =20
id=3D"myid"<BR> name=3D"myname"=20
<BR> =20
class=3D"net.mycompany.eclipse.tools.core.refactoring.MyClass "><BR>&nb=
sp; =20
<enablement><BR> =
<with=20
variable=3D"affectedNatures"><BR> &=
nbsp; =20
<iterate=20
operator=3D"or"><BR> &n=
bsp; =20
<equals=20
value=3D"org.eclipse.jdt.core.javanature"/><BR>  =
; =20
</iterate><BR> =20
</with><BR> <with=20
variable=3D"element"><BR> &nb=
sp; =20
<instanceof=20
value=3D"org.eclipse.core.resources.IResource"/><BR > =
=20
</with><BR> =20
</enablement><BR> </renameParticipant> <BR> &l=
t;/extension></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>MyClass extends the=20
Nothing=20
anything more I=20
have to do?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I'll start a new thread on this part of =
the=20
issue.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>/Stefan</FONT></DIV>
<DIV><FONT face=3DArial size=3D2> </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>"Stefan Junsved" <</FONT><A=20
href=3D"mailto:stefan.junsved@comactivity.net"><FONT face=3DArial=20
size=3D2>stefan.junsved@comactivity.net</FONT></A><FONT face=3DArial =
size=3D2>>=20
wrote in message </FONT><A =
href=3D"news:ddchc0$3a9$1@news.eclipse.org"><FONT=20
face=3DArial size=3D2>news:ddchc0$3a9$1@news.eclipse.org</FONT></A><FONT =
face=3DArial=20
size=3D2>...</FONT></DIV><FONT face=3DArial size=3D2>> Hi =
again.<BR>> <BR>>=20
across=20
<BR>> the same problem as I have?<BR>> Maybe the title wasn't =
enough=20
carefully chosen. My ambition is to find out <BR>> how to do a rename =
on a=20
resource, and using the built in IDE functionality <BR>> for that as =
much as=20
possible. Isn't it possible to provide the <BR>> refactor->rename =
with=20
extensive functionality for a certain type of <BR>> resource, and =
when=20
exactly that type of resource is to be renamed, the <BR>> provided=20
functionality is executed.<BR>> <BR>> I mean, in the editor case, =
you just=20
create a plugin with desired editor <BR>> type, and in the extension =
point=20
for the editor you say what file extension <BR>> should trig this =
editor.=20
It's extremely simple and genoius. Couldn't this be <BR>> the for all =
refactoring functionality in the IDE?<BR>> <BR>> /Stefan<BR>> =
<BR>>=20
size=3D2>>=20
wrote in message <BR>> </FONT><A=20
href=3D"news:ddagvb$e5$1@news.eclipse.org"><FONT face=3DArial=20
size=3D2>news:ddagvb$e5$1@news.eclipse.org</FONT></A><FONT face=3DArial=20
size=3D2>...<BR>>> Hi =
all.<BR>>><BR>>><BR>>> <BR>>> I=20
have several resources in my workbench described in xml but edited with=20
<BR>>> different GEF editors. I would like to hook into the =
Eclipse=20
Refactor -> <BR>>> Rename functionality when changing the name =
of an=20
xml resource.<BR>>><BR>>><BR>>> <BR>>> I have =
read quiet=20
a lot about this, but it seems as if most issues take <BR>>> care =
of how=20
to rename Java packages, classes, methods, and fields etc, <BR>>> =
etc. I=20
have not found anything about a more generic functionality on how =
<BR>>>=20
to rename any resource not being a Java=20
resource.<BR>>><BR>>><BR>>> <BR>>> I'd very much=20
appreciate some help with =
this.<BR>>><BR>>><BR>>> <BR>>>=20
/Stefan Junsved<BR>>> <BR>> <BR>></FONT></BODY></HTML>
------=_NextPart_000_000C_01C59E5C.5EAD9060--
FUDForum. Page generated in 0.02897 seconds
