Notify resource change [message #289551] |
Mon, 08 August 2005 08:23 |
Originally posted by: vducloux.cosmosbay-vectis.com
Hi, I'm developping a visual editor for my specific type of files (xml-like)
My Eclipse editor represents an xml file as a table. What I would like
is that as soon as an user edits a value of a table, the eclipse button
"Save" shoul appear.
I would like notifying eclipse that the related resource changed and
that it should propose the save action.
anyone knows how to implement this ?
thanks in advance,
Victor
Re: Notify resource change [message #289572 is a reply to message #289551] |
Mon, 08 August 2005 13:37 |
Originally posted by: sunil_kamath.nohotspammail.com
"Ducloux Victor" <vducloux@cosmosbay-vectis.com> wrote in message
news:dd74qn$p6v$1@news.eclipse.org...
> (xml-like)
> My Eclipse editor represents an xml file as a table. What I would like is
> I would like notifying eclipse that the related resource changed and that
> thanks in advance,
First:
firePropertyChange(IEditorPart.PROP_DIRTY);
Next, your editor isDirty() method should return true.
Sunil
Re: Notify resource change [message #289588 is a reply to message #289572] |
Mon, 08 August 2005 14:40 |
Hi, thanks so much for the help Sunil !!
Just one thing , how can I do a firePropertyChange(IEditorPart.PROP_DIRTY);
from an CellModifier ???
or am I doing it wrong ?
thanks very much
>>(xml-like)
>>thanks in advance,
> First:
> Sunil
Re: Notify resource change [message #289591 is a reply to message #289588] |
Mon, 08 August 2005 14:47 |
news:dd7qs6$aq5$1@news.eclipse.org...
> thanks very much
The cell modifier should update your model.
When your model changes, it should fire a notification.
The editor part should listen for the model change.
Then the editor part should firePropertyChange(IEditorPart.PROP_DIRTY)
Sunil
Re: Notify resource change [message #289594 is a reply to message #289591] |
Mon, 08 August 2005 15:30 |
Hi, thanks a lot, I get it know.
I'm really very new to all this so...
Do you know any tutorial ore something where I can get more infos...
So know I will add a boolean property in my model called isModified...
but afterwards I don't know how to do this listening stuff...
Thanks in advance and sorry for disturbing you again,
Victor
>>thanks very much
> Sunil
Re: Notify resource change [message #289641 is a reply to message #289594] |
Tue, 09 August 2005 14:36 |
Please, I'm really knew to all this, is there anyone than can help ??
thanks in advance
Victor
> Victor
>>> thanks very much
>> Sunil
Re: Notify resource change [message #289650 is a reply to message #289641] |
Tue, 09 August 2005 15:12 |
news:ddaf1d$gfb$1@news.eclipse.org...
> thanks in advance
This is the standard Java event paradigm.
Let your model issue an event whenever it changes.
Your editor part should add itself as an event listener to the model.
When it receives a model changed event, it can fire the
IEditorPart.PROP_DIRTY property change.
Sunil
FUDForum. Page generated in 0.06469 seconds
