Trouble installing [message #289516] |
Sun, 07 August 2005 07:09 |
Originally posted by: jai99999.yahoo.com
I have java 1.4.2_04 sdk installed.I tried installing eclipse 3.0.2 on my
PC. But I got an error message asking me to view the contents of the file
1123375023378 in the configuration folder.
Its contents are:
!SESSION Aug 06, 2005 17:37:04.129
eclipse.buildId=M200503110845
java.version=1.3.1_01
!ENTRY org.eclipse.osgi Aug 06, 2005 17:37:04.139
!MESSAGE Error registering XML parser services.
!STACK 0
java.lang.ClassNotFoundException: javax.xml.parsers.SAXParserFactory
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
org.eclipse.core.runtime.adaptor.EclipseAdaptor.registerEndo rsedXMLParser(EclipseAdaptor.java:272)
org.eclipse.core.runtime.adaptor.EclipseAdaptor.frameworkSta rt(EclipseAdaptor.java:253)
org.eclipse.osgi.framework.internal.core.SystemBundleActivat or.start(SystemBundleActivator.java:61)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:958)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:954)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:937)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:553)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:477)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:273)
org.eclipse.osgi.framework.internal.core.StartLevelManager.l aunch(StartLevelManager.java:243)
org.eclipse.osgi.framework.internal.core.SystemBundle.resume (SystemBundle.java:166)
org.eclipse.osgi.framework.internal.core.Framework.launch(Fr amework.java:425)
at org.eclipse.osgi.framework.internal.core.OSGi.launch(OSGi.ja va:51)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:216)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:127)
at java.lang.reflect.Method.invoke(Native Method)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
!ENTRY org.eclipse.osgi Aug 06, 2005 17:37:04.339
!MESSAGE Startup error
!STACK 1
java.lang.NoClassDefFoundError: org/xml/sax/helpers/DefaultHandler
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$100(Unknown Source)
org.eclipse.core.runtime.adaptor.PluginConverterImpl.parsePl uginInfo(PluginConverterImpl.java:557)
org.eclipse.core.runtime.adaptor.PluginConverterImpl.fillPlu ginInfo(PluginConverterImpl.java:111)
org.eclipse.core.runtime.adaptor.PluginConverterImpl.convert Manifest(PluginConverterImpl.java:660)
org.eclipse.core.runtime.adaptor.EclipseBundleData.generateM anifest(EclipseBundleData.java:233)
org.eclipse.core.runtime.adaptor.EclipseBundleData.loadManif est(EclipseBundleData.java:191)
org.eclipse.core.runtime.adaptor.EclipseBundleData.getManife st(EclipseBundleData.java:159)
org.eclipse.core.runtime.adaptor.EclipseBundleData.loadFromM anifest(EclipseBundleData.java:280)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultBu ndleData.initializeNewBundle(DefaultBundleData.java:77)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultAd aptor$1.begin(DefaultAdaptor.java:451)
org.eclipse.osgi.framework.internal.core.Framework.installWo rkerPrivileged(Framework.java:746)
org.eclipse.osgi.framework.internal.core.Framework$2.run(Fra mework.java:664)
org.eclipse.osgi.framework.internal.core.Framework.installWo rker(Framework.java:715)
org.eclipse.osgi.framework.internal.core.Framework.installBu ndle(Framework.java:659)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.i nstallBundle(BundleContextImpl.java:219)
org.eclipse.core.runtime.adaptor.EclipseStarter.installBundl es(EclipseStarter.java:800)
org.eclipse.core.runtime.adaptor.EclipseStarter.loadBasicBun dles(EclipseStarter.java:429)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:222)
!ENTRY org.eclipse.osgi Aug 06, 2005 17:37:04.379
!MESSAGE Bundle
initial@reference :file:e:/beproject/eclipseold/plugins/org.eclipse.core.runti me_3.0.2/
[1] was not resolved.
Can anyone make sense of this???
Thanks.
Re: Trouble installing [message #289525 is a reply to message #289516] |
Sun, 07 August 2005 17:37 |
Originally posted by: wegener.cboenospam.com
Jai wrote:
> Hello,
> my PC. But I got an error message asking me to view the contents of the
> file 1123375023378 in the configuration folder.
> Its contents are:
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
snip...
> !MESSAGE Bundle
> Thanks.
You may have java 1.4.2_04 installed, but your system path has a
1.3.1_01 vm prior to the 1.4.2 vm. You should search the newsgroup
before posting questions. This question comes up quite often.
You need to supply the path the the 1.4.1 vm to eclipse on startup with
the -vm argument.
FUDForum. Page generated in 0.02216 seconds
