finding bundle name? [message #289433] |
Thu, 04 August 2005 17:16 |
Originally posted by: sgollery.cadrc.calpoly.edu
Is there a way for a class to find out the name of the bundle that is
contained in, or alternately to get the Bundle object itself? I see how to
do that if the class is derived from WorkbenchPart, but what about classes
that are not part of any specific class hierarchy?
Steve Gollery
Re: finding bundle name? [message #289434 is a reply to message #289433] |
Thu, 04 August 2005 17:31 |
Originally posted by: sunil_kamath.nohotspammail.com
"Steven Gollery" <sgollery@cadrc.calpoly.edu> wrote in message
news:4f2cd67cb6789549acc5ab526a5c3b51$1@www.eclipse.org...
> Steve Gollery
bundle.getHeaders().get("Bundle-Name")
Re: finding bundle name? [message #289435 is a reply to message #289434] |
Thu, 04 August 2005 17:50 |
>> Thanks,
>> Steve Gollery
Sunil,
I'm hoping to avoid having to put the bundle name into the code or into a
properties file or something. In other words: starting with no Bundle
object and no bundle name, can a class find out what bundle it is part of?
Steve
Re: finding bundle name? [message #289437 is a reply to message #289435] |
Thu, 04 August 2005 19:35 |
news:ccdab9f80b4e1eb1e39e50116eb708da$1@www.eclipse.org...
>>> to do that if the class is derived from WorkbenchPart, but what about
>>> classes that are not part of any specific class hierarchy?
>>> Thanks,
>>> Steve Gollery
> Sunil,
Starting with no Bundle object?
Why would you want to do that?
And "Bundle-Name" is not the actual bundle name, but the name of the
manifest attribute which points to the bundle name.
Sunil
Re: finding bundle name? [message #289438 is a reply to message #289433] |
Thu, 04 August 2005 20:21 |
Originally posted by: john.eclipsefaq.org
You at least need access to a BundleContext, passed to the
BundleActivator.start(...) method. Once you have the context:
Object object = ...; //the object you want to find bundle for
BundleContext context = ...;
ServiceReference ref =
context.getServiceReference(PackageAdmin.class.getName());
if (ref != null) {
PackageAdmin admin = (PackageAdmin)context.getService(ref);
Bundle bundle = admin.getBundle(object.getClass());
bundle.getSymbolicName() -> voila...
> Steve Gollery
Re: finding bundle name? [message #289440 is a reply to message #289438] |
Thu, 04 August 2005 22:07 |
> if (ref != null) {
Which works fine unless you've created a plugin from an existing Jar file,
in which case there is no BundleActivator class in the plugin.
But I've worked out another way to solve the problem that I thought I
needed a bundle for, so thanks to you and to Sunil for your input.
Steve
>> Thanks,
>> Steve Gollery
FUDForum. Page generated in 0.03201 seconds
